2000 mazda mpv could start without the dash assembly and speedometer
I think it may be an electrical issue but I think it's just a fuse. There are 2 fuses I would check. One of them is a 15 amp fuse inside the fuse panel inside the vehicle (see fuse layout below) and the other is a 40 amp fuse in the fuse panel under the hood of the vehicle in the engine compartment (see other picture below). I marked the fuses to check and hope this is the problem.
SOURCE: 1990 mazda mpv
Speedometer cable is broken. Don´t speed more than 35mph until a new speedometer is replaced.
SOURCE: 2003 Mazda Tribute Electrical Issues
sounds like you have a wire grounding out some where trace the wires under the dash and look for broken or chaffed wires. that might be touching the fire wall
SOURCE: 2000 mazda bogging in all gears especially in 1st and 2nd gears ?
Judging from what i know, the timing on the engine is probably a bit off, and i remember reading the exact same problem on another web site and that is also what they said. So just check the timing on the engine or have it checked by a mechanic if you don't know how to do it.
SOURCE: possible electrical problem 2000 Mazda Protege?
sounds like a corroding wire within the harness
SOURCE: 2000 mazda Mpv stuck in park it wont change into
check your brake light switch. Do your brake lights work?
