I recently converted it over to a 12 v neg. ground ign. system with a new 12 v single wire alt. and a 12v hot coil. It previously was a 6v pos. ground .sys. The problem is that it starts and runs for about 5 sec. and then shuts off. It is getting fuel and plenty of spark. I set the timing and set the points to .020. The battery is brand new but when I checked the charge , it was a little low. Do you think the battery being a little low would be causing the tractor to stop running?
SOURCE: it is a 1947 farmall
Two possibilities come to mind:
- the water pump impeller may have so much oxidation on it, it's not pumping enough coolant
- the cooling circuit in the block has so much oxidation in it that it is restricting the coolant flow rate through the block
It's like my arteries, I'm the same age as your tractor, and believe it or not my father once owned that same tractor.
I don't remember, does it have a thermostat? . If it does, you could remove it -- that might help.
SOURCE: 1942 farmall tractor stalls after 10 - 15 minutes of bushhogging.
I think you still have a fuel issue like your float level is to low,I hope this helps you
SOURCE: Farmall Cub 1955, runs fine for about 20- minutes
I have cub that done same thing, there was crud in orfice between tank and sediment bulb, cleaned orfice, runs fine.
SOURCE: hello my dad has a
HI, depends on how it sounds. It is the Gear box that controls the Gear. When it get's damaged it makes a noise as a sign that something is wrong somewhere. And when you select a Gear it will not be able to move it shakes the tractor a little and goes off...
But you might not be certain at this moment in time, depending on the sign it has been given before it started acting this way.
Also you can still check the axle belt.But i would advice you do a General troubleshooting for the tractor to be really sure where the damage is from and if it has damaged another part on the tractor..
Also make sure you check for low oil too,that causes a lot of damage to tractors..
Good luck to you.
SOURCE: tractor stalls after approx. 15-20 of run time (1957 farmall cub)
Could you be having a fuel supply problem? I have a 1957 Farmal Model 100 and has its own problem caused by moisture building up in the distributor SLOCITYJOHN
