SOURCE: how do I remove the towel bar from the wall?
on both ends look underneath and there is a tiny hole with an Allen/hex head insert u turn counterclockwise wise and loosen srew until you can tilt end upwards towards the wall, reverse to install
SOURCE: Tighten up a loose Moen Eva towel bar wall mounted bracket
u have to really push hard up on the spring and at the same time pull towards u
SOURCE: How can I attach a ceramic towel bar inside a tub
You could use a good water proof glue but that would only work for a short while. What kind of material is the surrounding made of? Ceramic towel bars are normally set in ceramic surroundings. If you really must have this towel bar you may have to cut two squares out of the surrounding and put in two ceramic tiles, that way you can put ceramic on ceramic.
I need a plate to mount between the wall and the new brackets to conceal the extraa holes
