We are getting error code nd, how do we check the pump for blockage or determine if the pump is broken?
My maytag naptune mah9700 front loader error code is "nd" what do i do
You need to remove the front cover by removing th escrews holding on the door hinge nad 2 other screws oppisite the hinge, after taking off screws the front "u" shaped panel will pull foward and off( hoeld on by 2 clips along the bottom. the drain pump is located right back corner of machine..ill assume that the machine is still full of water so youll need ot **** out as much as possible before removing the hose connected to the pump. theris going to be some water no matter how much you remove nut might as well get as much as you can. youll either find debris in hose, or debris lodged in imoeller of pump, even seen coins standing in the plastic hosing preventing flow of water.VERY< VERY rarely bad pump ussually just a clog.IMPORTANT UNPLUG UNIT FIRST LOTS OF LIVE WIRES UNDER HERE
trying to solve nd code problem
