Question about Panasonic Microwave Ovens
Microwave has power, but nothing works.
Panasonic NNSD291S over the range microwave. The unit has power, clock and timer function, but virtually nothing else works.The stove facing lights and fans do not work, the interior light doesn't function either. When activated, the Microwave timer goes down about 3 seconds without the microwave actually functioning, then it stops the timer and returns to the clock setting. Any help??
  • john chacko Jul 02, 2013
    not working
    nn-6358 not working
  • Panasonic Master
  • 6,771 Answers
The door switches are more than likely the problem, one or two will need to be replaced, I recommend a professional.
Posted on Mar 19, 2012
SOURCE:
  • 38 Answers
SOURCE: Nothing happens when you press "Start"
PLEASE CHECK IF DOOR IS CLOSED PROPERLY THOSE HOOKS ON THE DOOR ACTIVATE SWITCHES ON THE INSIDE OF MWAVE OPEN COVER AND CHECK IF HOOKS ARE MAKING CONTACT WITH SWITCHES .COULD ALSO BE TOUCHPAD FAULT YOU WILNEED A TECH
Posted on May 09, 2007
fridgetech
  • 473 Answers
SOURCE: Panasonic NN-2501 Microwave Oven range hood
It is possible that the magnatron is bad but hard to say on a no heat problem without checking all components. A lot of model give 5-7 yr warranty on that part.
Posted on Oct 05, 2007
MicrowaveSvc
  • 9156 Answers
SOURCE: Whirlpool Gold Microwave Model GH7155XHS
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 09, 2008
jeltey
  • 44 Answers
SOURCE: JVM1190 wont cook
You have a blown actuator. This is the device that creates the microwaves that cook the food. The cost of one of these will be as much as a new unit.
Posted on Nov 09, 2008
MicrowaveSvc
  • 9156 Answers
SOURCE: Maytag over the Range Microvave MMV5186AAS does not heat.
You have a bad secondary interlock (top door switch) or its mount is bad.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Jan 01, 2009
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    Everythink works except the microwave will not start. Is there a fuze that can be replaced to fix this ? Model # NN-2551 I found the user manual on-line, but I can't find the product spec sheet breakdown...
    I'm not sure what you mean by "everything works". do you mean that all the lights and the timer work. Could it be in the timer or clock mode? Try pushing the timerand cancel buttons together.
    Try changing the time using the clock function.
    I believe your model has a child lockout. Please check your manual for instructions on unlocking this function.
    Is it hardwired or plugged in? If it is plugged in you can try a power reset, by unplugging it, waiting a few minutes and plugging it back in. It is completely unsafe to try to work on a hardwired Microwave.
    Please let us know if this solution is helpful to you. Thank you.
    Dec 20, 2010 | Panasonic NN-S255 Microwave Oven
    How do I get my Panasonic Inverter microwave out of demo mode? I think my toddler might have hit something to put it in demo!
    Hello Two options to try: a) Press the Clock / Timer button 3 times b) Unplug, wait a few seconds, then re-plug to power up with the factory settings. You will need to reset your clock and any favourite settings.
    This should work with all Panasonic Microwave models.
    Good luck
    Aug 10, 2010 | Panasonic NN-H275 Microwave Oven
    11 yr old range/oven ; oven stopped working (clock is out and everything) : stove top is fine. Major expense ro fix ? Am I better off getting new one ?
    your clock controls the oven functions. replace clock. probally a little cheaper than a new range but depends on service call fees and labor
    Jun 22, 2009 | Kenmore 63792 Microwave Oven
    Has power to unit but nothing works, ie. oven, clock, timers, etc
    If you don't see any light in the display or from the light bulb inside it you probably need to replace the fuse inside the microwave, it should be by the place where the cord goes in the microwave.
    Apr 08, 2009 | General Electric Microwave Oven
    JVM1190 wont cook
    Nov 09, 2008 | GE JVM1190 Microwave Oven
    Microwave not working
    The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
    If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
    Otherwise, your controller or keypad may have moisture on it.
    Sep 08, 2008 | Panasonic Microwave Ovens
    Microwave Ovens Logo
    581 people viewed this question
    Top Panasonic Microwave Ovens Experts
    William Miller
    William Miller
    Jerry Greenberg
    Jerry Greenberg
    Steve Allison
    Steve Allison
    Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
