Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
OLGUER CORONEL Posted on Mar 18, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I NEED LAMP MODEL KDFE42A10
MY TV IS SONY PROYECTOR MODEL KDFE42A10 AND I NEED BUY 2 ALAMPS MODEL
Anonymous
Level 3:
Top Expert:
  • Sony Master 14,553 Answers
  • Posted on Mar 19, 2012
Anonymous
Sony Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2715358
Points
48227
GOOGLE the model number with lamp after it and you will find dozens of places happy to sell you one or more.
5 Related Answers
Anonymous
  • Posted on Jun 11, 2009
SOURCE: sony model kds-55a2000
Go to projectorlampexperts.com
Anonymous
  • 1015 Answers
  • Posted on Jan 09, 2010
SOURCE: sony projection lamp is nearing end of life
Here is a link to a website that sells the replacement lamp for $99 dollars. http://electrified.com/Catalog/Items/?CampaignID=Dealtime&ItemID=36414
There might be a local store in your area that carries replacement lamps but probably will not have yours in stock and would have to order it. After you replace the lamp you will need to reset the lamp timer for your TV using the lamp replacement option on the TV general settings menu.
Anonymous
  • 171 Answers
  • Posted on Aug 02, 2010
SOURCE: blue
this is usually caused by dirt inside the light engine.  it needs to be sent in to sony or a rebuild company to be cleaned or replaced.  not user/operator repair....
zorbrack
  • 19 Answers
  • Posted on Jun 12, 2011
SOURCE: Replaced lamp from Sony in
your optical block is failing. Sony has a program for replacing them if you want, or they will offer you a new TV. call this number 239-768-7604 and tell them what you TV's symptoms are and they will get you started
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Jul 14, 2011
SOURCE: hi, i want to know
which board are you needing that model has alot of boards in it such as the G board, D board, A board, B Board, and etc. Let me know the symptom or which board and I will assist you with the issue.
My sony projection tv model number KDFE42A10 It work's fine but after 10 minutes or so the picture will go out then the green will flash 49 times then the picture comes back on for awhile then does same...
This is an easy problem. Your lamp is bad. Do not buy a cheap lamp. They are dim and won't last. I always recommend you buy the sony lamp. Also clean out all dust in back and side of tv..jeff the tv doctor
3helpful
Replaced lamp from Sony in January. In the last month or so been noticing a large yellow spot in the middle of screen. My TV is a Grand Wega LD Projection TV Model No. KDFE42A10, Serial #9507132.
When I turn the tv on it stays on for a few seconds, and then cuts off
is the power light or lamp light blinks? if its the lamp then replace it. your tv lamp model # XL-2400. check this link https://servicesales.sel.sony.com/ecom/accessories/web/viewItemDetail.do?operation=getItemDetail&itemID=600259&searchOperation=modelSearch&searchText=KDFE42A10
or if its the power light that blinks then turn off tv for 5 mins. unplug power cord for 1 min. try plugging the power cord directly into working wall outlet. if same, tv needs service. visit eservice.sony.com website to check service option
How do i replace the lamp bulb in sony tv kdfe42a10
There are several online video tutorials that are available online. If you search some of the websites that seel the lamp, most have a tutorial.
You'll need...
1. a Phillips screwdriver
2. a 7mm (I believe) nut driver
3. Needlenose pliars
4. Gloves to keep acid from your skin getting on the lamp. The company I bought my lamp from provides cotton gloves (www.bulbsolutions.com)
Remove 3 screws from housing (2 on each side, and one that holds front of housing to the back of the housing)
Remove 2 mounting screws in corner of lamp that holds lamp securely to the lens.
Remove nut holding wiring harness to lamp
Remove screw holding wiring harness to lamp
1helpful
Sony 52inch KDFE42A10 picture gone, buzz, red
Yes. It's in the owners manual. Lamp model # XL-2400 , p/n 93087500
Bulb pop and picture is out
Here is a link for a replacement Philips lamp for your TV model. Don't worry if it doesn't say Sony on the box as Philips makes the lamps for Sony anyway. Pleas take a moment to rate my answer. Thanks...
http://www.partstore.com/Part/Royal+Philips+Electronics/Philips+Lighting/F93087500RL/New.aspx?ModelMfgName=Sony&ModelBrandName=Sony&ModelNumber=KDFE42A10
Replacing tv lamp
check your connections on your tv
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
