Motorola Mobility Bluetooth Headset-Silver/Black Headset Logo
Posted on Nov 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Audio on h700c
When I answer a call I can hear but the person I'm speaking to can't hear me well
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Dec 31, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
8532
Points
7
Hi--While you're having a conversation, either with or without bluetooth, make sure your phone's volume is turned up.  On a lot of phones the volume button will control both ringer and conversation volumes, but turning it up without the phone in use only affects the ringer volume.  My husband thought there was something wrong with his bluetooth until we noticed his phone volume was set too low--not as noticeable on handset, but bluetooth apparently needs volume up pretty high!
Damen Wong
Level 3:
President:
  • Master 1,950 Answers
  • Posted on Nov 06, 2008
Damen Wong
Master
Level 3:
President:
Answers
1950
Questions
0
Helped
1027415
Points
5739
Check to see if you have not muted the headset or the phone.
When I try to talk in my GH20 at Skype the person I speak with can hear me. But I cannot hear the other person. But I can listen to music in the headset. What is wrong? Please help!
If you cannot hear the other person then, your the speaker may not configured inSkype.
To configure thespeaker - Open Skype - Tools - Options -Audio Settings - Speakers select your audio card, check the volume slider THEN click on Save.
When someone calls me, they can't hear me if I have my bluetooth in, but I can hear them...I have the Motorola H700C wireless headset.
I have, no-had, two of these H700C. The microphone in both of them failed about when yours did. I had previously split the boom and removed the foam covering the mic due to callers complaining they could not hear me. No solution here as far as I can see, except replacement. I don't understand it, either.
I cant make a pc to pc call, whats wrong?
Dear Friend You Need Following
  • Messenger
  • Audio card(It must be on your System if your System New)
  • Mic
  • Head set
  • Inter Net Connection
  1. Install Messenger
  2. Sign in Messenger
  3. Configure Audio (it will automatically configure)
  4. Add ID you want to call(ID is basically mail address of a person you want to contact;it is said to be Mail address)
  5. Click on ID
  6. Click on CALL button
  7. It will answer the person you want to call(He/She Should be on-line at the time of Making Call)
  8. You are Connected
Check this things..
  • CHECK YOUR SOUND CARD
  • Check your MIC
CONFIGURING.....Do following...
  • Open Messenger(there you will see at top Messenger,Contacts,Actions etc.)
  • Click on ACTIONS
  • Click on CALL SETUP
  • Click on NEXT (You will see a tab for Configuring Sound Set-up)
  • Try to Speak (you can see YOUR SIGNAL of SPEAKING)
  • You are Sucssesfully Configured MIC
  • Click Next (you will hear SOUND)
  • Click Finish
You are Done.. I tried to give you Detailed instruction.... is THIS tExT Helped YOu.....
Rate ME ....
Thanks For Using FixYa
1helpful
Audio Problems!
You have the mute function turned on. See the book that came with it.
5helpful
2answers
Persons on the other end can't hear me speak
hi,
go to menu, then admin setup, then diagnostics, you can adjust the mic levels in there, they are 50% by default.
H700C Low audi volume
The head set just started to have low audio. People can hear what I am saying. I can't hear them.
2.gif How do I fix it?
H700c, I can hear butothers can't hear what i speak.
With this problem, the headset will have to be replaced.If you had it less than one year Motorola can replace it free of charge with purchase recipe. contact Motorola.
Wireless bluetooth headset
  • press the answer button at the side of the headset
Top Motorola Mobility Radio Communications Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
