Norstar Merdian
Press Feature.
Enter "**8463".
Enter the password (default is 266344). The display shows
Hour: 01
Next Change
Select CHANGE. Display shows:
Hour: __
Cancel
Enter two digits for the hour. Chose AM or PM when Prompted.
Select NEXT.
The display shows:
Minutes: 00
Next Change
Enter the minutes.
Press the RLS button to end, or press NEXT to change the date.
The diplay shows:
Year: 99
Next Change
Enter the two-digit year.
Select NEXT and repeat to change the month and day.
Press the RLS key to save the time and date and exit programming.
Top of Page
Norstar Meridian CICS
Time
- Press "FEAT".
- Press "*".
- Press "*".
- Press "266344" (CONFIG) or "23646" (ADMIN).
- Enter password "23456" (ADMIN) or "72787" (SCPLUS).
- You will see "Terminals & Sets".
- Press "Next" five times.
- Press "Show"
- When you see "Hour", press "Change" or "Next" to skip.
- Type in the hour using military time as a 2 digit number.
- Press "Next".
- When you see "Minutes", press "Change" or "Next" to skip.
- Type in the minutes using a 2 digit number.
- Press "Next".
Date:
- When you see "Year", press "Change" or "Next" to skip.
- Type the year in 2-digit format.
- Press "Next".
- When you see "Month", press "Change" or "Next" to skip.
- Type the month in 2-digit format.
- Press "Next".
- When you see "Day", press "Change" or "Next" to skip.
- Type the day in 7-digit format.
- Press "Next".
- When you see "End of List", Press "Rls" to exit.
Top of Page
Nortel Norstar Telephone Systems
Changing the time on a Norstar system must be done using a display
phone. Using a M7310 or T7316 the right 2 buttons under the display are
"NEXT" and "SHOW" respectively.
- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
- Enter password (default = 266344) - display should read "Terminals & Sets"
- Press "NEXT" 5 times - display should read "Time and Date"
- Press "SHOW" - display should read "Hour:___"
- Press softkey "CHANGE"
- Enter hour - display should read "AM OK or Change"
- Select AM or PM
- Press "NEXT" - display should read "Minutes:___"
- Enter minutes
- Press "NEXT" - display should read "Year:___"
- Enter year
- Press "NEXT" - display should read "Month:___"
- Enter month
- Press "NEXT" - display should read "Day:___"
- Enter day
- Press "NEXT"
