Lutron AY603P Ariadni 600W 3way Dimmer whiteivoryalmondlight almondgr Logo
Gene Sparrow Posted on Mar 17, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Using 3 way dimmer, lights don't appear to go to full light
Steve
Level 3:
  • Master 3,290 Answers
  • Posted on Mar 21, 2012
Steve
Master
Level 3:
Answers
3290
Questions
Helped
1127428
Points
12184
Hi Gene,
When two 3-way switches are used to control a light - and you wish to install a dimmer, you replace only ONE of the switches. If you replace both switches with dimmers, and one dimmer is set to 50%, the light will only be able to get to 50% bright; regardless even if the other switch is set to 100%. The light can only get as bright as the current lowest dimmer position of either switch.
Most modern dimmers are solid state, and should be able to get full power to the lamps. Older dimmers aren't very efficient and work a little differently - but should still do a good job as far as brightness of the lamp. You can run into trouble trying to dim CFL (compact fluorescent lamps) if they are not labeled specifically for use with a dimmer. Even those that are labeled for use with a dimmer have a noticeably short range of dimming when compared to standard tungsten lamps, and tend to have an audible buzzing sound.
If this doesn't answer your question, please provide the wattage, type and number of lamps in the fixture. Your dimmer is rated for up to 600 watts, but may be less if it is in a switchbox with other dimmers or you have broken off portions of the heat shield as directed by the instructions.
5 Related Answers
VtToolMan
Mark
  • 704 Answers
  • Posted on Sep 10, 2009
SOURCE: LUTRON DIMMER
The Lutron Maestro dimmer isn't rated or designed to operate low voltage lighting as it is a 120 V-AC rated electronic dimmer. You should either install a standard low voltage ON/OFF switch on this installation or obtain a dimmer rated for use on low voltage lights.
You need special low voltage dimmer designed for use on the low voltage pucks lights you have installed. Usually the low voltage is either 12, 24, or 36 volts, depending on the manufacturer of your particular light set. Once the correct dimmer is in place, the problem with the flickering and pulsing of the lights, should cease.
If you still are having this problem and you can't find a low voltage dimmer, you can contact the maker of your low voltage light kit and they can provide you with an acceptable dimmer option for your lights.
Most Home Depot and Lowe's carry the low voltage puck light kits, and usually have accessories for these lights, including dimmer switches that will work with them.
Hope you find this Very Helpful and best regards!
PS: I found this old, unanswered question and wanted to provide a solution to close out the problem and clear the question from the site.
Anonymous
  • 3 Answers
  • Posted on Jan 05, 2010
SOURCE: I am replacing an old dimmer switch with a new
ON one side of your switch it is connected with a small peice of metal or should be. That is why it only explains 3 wire instead of 4. If you look you can find the one you need with 4 spots to put your wires. Just look or ask your store for what you need. They can be very helpful in helping you find what your looking for. Hope this helps.
Anonymous
  • 66 Answers
  • Posted on May 22, 2010
SOURCE: wiring Question
No, the way the motor speed control works is different from the way a light dims. If you connect it, it might work for a while, but it will either burn up the dimmer or the fan motor.
Anonymous
  • 1489 Answers
  • Posted on Jan 08, 2011
SOURCE: installed a 3 way dimmer switch and now the lights
If you could describe the previous lights/switches configuration and how it was changed, I think I can help solve your problem.
Charlie
Anonymous
  • 107 Answers
  • Posted on Sep 12, 2011
SOURCE: I am replacing a Lightolier
It depends. Some dimmers are considered "smart dimmers," where the control on the other end of the 3-way has to be intelligent enough to send a signal back to the dimmer. If the Lightolier dimmer was a smart dimmer, then chances are that the 3-way control was designed to talk only to that specific dimmer. The Leviton product you replaced it with is a simple, basic dimmer - it should work in conjunction with a simple, basic 3-way switch.
If the 3-way control already IS a simple, basic 3-way switch - then I would simply re-check the wiring of the dimmer you replaced.
1helpful
I want to install the 18023 ge dimmer in the middle of a 4-way switch
Bob, Not quite enough info to be sure how you have this wired, but here's a shot. 3 or 4 way dimming switches are designed to work with other 3 or 4 way on-off switches, not with another dimmer. I never tried this but it is no surprise that it might work only if you keep the dimming function of switch C in the full-bright position, because you are using two dimmers wired in series. For best operation, you should replace C with a regular 3 or 4 way switch.
Need help 2001 chev cavalier running lights work but low &high bean lts don't
Someone will need to check for voltage at the dimmer switch and then trace back to the fuse box as needed.
93 ford taurus no dash lights
1st thing to check is to make sure you don't have the dimmer wheel turned off by the main headlight switch to the left of driver.
How to do energy saver dimming ?
Most modern dimmers provide normal energy savings. They reduce the total amount of watts consumed on the circuit. Many years ago, dimmers only reduced the watts consumed as light - making up the difference as heat in the dimmer switch. A 100W light turned down to 1/2 wattage at a dimmer switch resulted in 50 watts of light at the bulb, but 50 watts of heat was created in the switch. That was zero energy savings. The newer electronic dimmers will still let 50 watts be used as light, but only a few watts as heat in the switch.
To maximized energy savings, use of new cold cathode technology lights such as CFL (compact fluorescent lamp), LED (Light Emitting Diode), etc. types are suggested. You can use these lamps on a dimmer to furrther reduce the amount of energy used - but only if the lamp indicates that it is dimmable.
If the lamp or fixture does not specifically state it can be used on a dimmer, don't. This includes powering a light through a dimmer that is set to maximum brightness. Use a standard non-dimming switch instead.
I hope this helps & good luck!
How to replace dimmer switch
Hi Karen,
There are two types of dimmer switches - single pole (or S1) and three way (or S3). You can determine which type you have without even removing a screw. Here's how: How many switches can control the light fixture now? One or more than one? If you answered one, you need a single pole dimmer switch. If you answered 2 or more (it doesn't matter how many at this point), you need a three way dimmer. Ok, we're done with step one almost.. make sure that the one switch that controls the light has ON and OFF on the toggle handle. Likewise, none of the multi-switch arrangements that control a light should have ON or OFF on the toggle handle. None of the wide rocker or Decora style switches have ON or OFF on them.
Next, do the light switches that control the fixture only control an incandescent light? If the switch operates a light AND a fan - like a paddle fan fixture - you can't simply replace the switch with a dimmer. Dimmers are for use with a 120 volt incandescent lamps (tungsten, quartz, halogen, etc.). They are not designed to work on motors circuits - such as fans - nor are they designed to work for lights that have a "ballast" like neon or fluorescent types or a "transformer" like low voltage track lights, etc.. Check the bulb's voltage rating if unsure if a low voltage type or not. The only exception to the above that I am aware of would be for lamps that SPECIFICALLY state on the package that they can be used with a dimmer. You can find dimmable compact fluorescent lamps that will work, but as far as I know, there are no other types of lamps or motors for that matter that will work WITHOUT OVERHEATING or DANGER OF FIRE.
A retail package of dimmable CFLs.
That means, yes; if you install a dimmer on a motor, it will adjust the motor speed BUT, the motor WILL over heat and can easily start a fire. The same holds true for lamps that have a ballast. If it doesn't specifically state it is for use with a dimmer, don't try to use a dimmer to control it.
Check the wattage rating of the fixture. There is a sticker affixed to every fixture that indicates the maximum wattage of each lamp socket. Add these values together. Most fixtures are well under 600 watts. This 600 value is significant, as this is the base rating for dimmer switches. Nearly all unmarked dimmers are rated for 600W - but if you look closely, you should find this wattage rating along with the voltage rating on it somewhere. If your fixture is capable of more than 600W, you should select a dimmer that is rated to at least handle this wattage. The next higher wattage rating for most dimmers is 1000W, and costs about twice as much as the 600W dimmer. It only gets more expensive from here. Fortunately, not many residential applications need 1000W+ dimmers for the loads they will control. The need for 100W+ dimmers comes into play when there is a dimmer switch in the same box as the old switch. When converting a dimmer & switch to a dimmer and dimmer in the same box, the wattage rating is derated to disapate the heat created by the dimmers. Please, consult the chart below to see how to properly derate:
http://www.residential-landscape-lighting-design.com/lighting_dimmer_derating_ganging.htm
Ok, the preliminary work is complete. Shut off the power to the circuit. Remove the wall plate and remove the mounting screws that secure the switch from the switch box. Gently pull the switch out of the box. If it is a single pole switch, it will have two (2) terminals. If it has 3 or more terminals, (not counting the green ground screw) skip ahead to the three way section. If there are more than 2 wires connected to the switch (again, not counting the green ground screw), mark the wires so that you know which wire(s) go to which terminals. Use masking tape and a pen to write or colored tape to identify all wires that connect to the same terminal. Turn power back on. Test the all the wires for the presence of 120 volts. Once this is learned, shut the power off again. Test to make sure power is indeed off. Remove the wires from the switch terminal screws. Remove any bare or green ground wire from the green screw. The new dimmer should be connected so that the the "power" or "line" wire or terminal is connected to the wire(s) that you found to be powered in the previous step. If there was 2 or more powered wires that had the same identification or mark on them when testing - make sure all those wires get connected to this terminal of the dimmer. Connect the remaining wire(s) (that should also ALL have the same marking) to the remaining "load" or "light" wire or terminal of the dimmer. Make sure the wires that connect with a supplied wirenut have no exposed metal to short out. Check your work. Make sure none of the marked wires have been mixed with the other marked wires. Connect any bare or green ground wire to the green or bare wire of the dimmer or green screw on the dimmer. Gently fold the wires to the rear of the box or sides and insert the dimmer. Secure to the box with screws and install the wall plate. Turn on power and test.
If you have a multi-switch or three way installation, it's a little more complicated. Firstly, only ONE dimmer is used in the circuit. Installing more than one dimmer will prevent the light from being made brighter than the current brightness setting of lowest switch. If there are 3 or more switches that control the light, two are three way types; and are the only ones that can be changed to a dimmer. The third, and subsequent switches in multi-switch installations are "four way switches". Dimmers are not made to replace them. Three way switches have 3 terminal screws and four way switches have four screws (not counting the green ground terminal screw). This is the only way to determine one from the other. Start by shutting off the power. Go to the switch that you would like to replace with the dimmer. Remove the wall plate and switch mounting screws. Gently pull the switch out of the switch box. Count the number screws on the switch body (do not count any green ground screw). If it has 3 screws, it's a 3 way. If it has four, its a four way and can not be changed to a dimmer. If it has 4 screws, resecure the switch into the switch box and reinstall the wall plate. You will need to find a three way switch that controls this light. If none of the other locations is not desirable, you can not install the dimmer. Otherwise, remove any bare or green wire from the green ground screw. Next, locate the dark colored screw. This is called the "common" or "shunt" screw. Sometimes it is painted black; and other times it is gold when all the non-ground screws are silver colored. In any case, it will be the "odd colored" screw. Mark the wire(s) that connect to this screw with a number "1". Mark the wire under one of the other screws (it doesn't matter which) with a "2"; and mark the wire under the remaining screw with a "3". The wires that are connected to these terminals and marked as number 2 & 3 are called "traveler wires". Traveler wires run between switches and common (or shunt) wires that connected to the terminal with the same name and marked as number 1 does one of two things: it either comes from the power source or it supplies power to the light fixture. Make sure each wire that was connected to the 3 way switch has a number on it, then remove all the wires from the switch terminals. You will connect your traveler wires numbered 2 & 3 to the dimmer's traveler wires or terminals (it does not matter which wire is connected to which terminal; and the common or shunt wire numbered 1 to the dimmer's common or shunt wire or terminal. Many dimmers use black as the common or shunt and red & white for travelers. You'll need to consult the wiring information that comes with the dimmer to find out the colors used for common or shunt and the traveler wires on your switch. Check your work. Make sure no exposed wire can short when it is powered up, later. Carefully fold the wires into the switch box. Insert the dimmer into and secure to the switch box. Reinstall the wall plate and turn power on & test.
I hope this helps & good luck! Please rate my replay.
1helpful
Dashboard lights do not come on !
check the cluster dimmer switch make sure not turned all the way down to keep instrument cluster lights from glowing brightly.if dimmer switch not turned way down look for blowed instrument cluster fuse.
1helpful
Hi I've got a Lutron electronic slide dimmer
Let's start whittling away some of the information...
First of all, the ZP260QE is from Lightolier,so you may want to give their tech support center a call.
Secondly, ignore the continuity tests, they tell you nothing. Continuity on the secondary is expected because you're on the output of a "true" transformer, which will look like a short on a DC-supplied continuity test. The input to an ELECTRONIC transformers is a switching power supply, which will not look like anything when supplied by a DC voltage/current during a continuity test. Those test results appear normal to me. The +/- 60 also makes sense, if you've measuring voltages on the output of a dimmer, the impedance of the dimmer's off-state and the impedence of the multi-meter makes for some screwy readings that don't always make sense.
Most dimmers rated for electronic low-voltage have protection circuitry built within them to make sure they're not overloaded. Normal incandescent dimmers will just get warmer than usual, these guys should shut down - perhaps that's what you're seeing.
My two suspiciions are either (a) the additional pendent light, combined with the existing track lights, tripped the overload protection, or (b) when you added the pendent light, you got too much of a current inrush that shorted out the components within the dimmer.
Lights don't give full light
didn't know you could use a fantech dimmer for regular lights.. try a regular 3 way switch in both places and see if you get full brightness then replace only one of the switches with a 3 way dimmer and see what happens.. you can only use one dimmer on a 3-way circuit
Top Lutron Electrical Supplies Experts
ADMIN Andrew
ADMIN Andrew
Eric Kalman
Eric Kalman
Level 1 Expert
Are you a Lutron Electrical Supply Expert? Answer questions, earn points and help others
