Question about Husqvarna Garden
Husqvarna riding mower modle yth20k46 that move very slow
Sir.# 1110080003704, mod.#yth20k46, product # 96450004, husqvarna riding mower that moves very slow soming is making a whining noise
The link rod from the petal to the transmission straightened out at the rear bend. Take it off and bend it slightly further to make it go forward faster. The 1/2" nut above where the rod connects to the transmission is adjustable to set it where it doesn't move when your foot is off the petal. Loosen it a bit and you can move the petal slightly forward or backward to adjust it. Depending on how much you bent the rod it won't take much adjustment. Re-tighten and try it out. It may take a few tries. Good luck!
Posted on Nov 28, 2014
SOURCE:
  • 76 Answers
SOURCE: murray riding lawn mower
with switch off try crossing out the solenoid. take an old screwdriver and place it on the two metal contacts jetting out from the solenoid usually by the battery or close to the ignition. if strarter engages when this is donr replace solenoid. if not replace starter. hope this helps.
Posted on Oct 28, 2008
  • 109 Answers
SOURCE: MTD PRO RIDING MOWER/LAWN TRACTOR 18 HP ENGINE HYDROSTATIC DRIVE
In the back of the mower...probably under the seat, there should be a lever to release the transmission, or it is on the back plate. As far as the noise when trying to move drive the mower, the brake in the back, next to the transmission is jammed, use a 1/2 inch wrench to loosen it maybe 1/4 turn and this should unlock the brakes
Posted on Apr 22, 2009
  • 33 Answers
SOURCE: husqvarna yth1842xp 2005 ride on mower won't move in gear
your linkage came apart from the way it sounds. most all these riding lawn mowers are simple machines. you need to fallow the(flopppy lever) and see where it go's it is supposed to attach to a rod or cable and must have came unhooked
Posted on May 02, 2009
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
panilling9
  • 284 Answers
SOURCE: what kind of oil for a husqvarna riding mower?
Yes Briggs and Stratton recommends sae 30 in most all their engines even overhead valve (OHV)
Kohler uses 10w-30 in most of their overhead valve engines
Briggs has their own bottled oil with their label and additives and can find at lowes
Kohler the same
Posted on Jun 14, 2009
Husqvarna YTH20K46 lawnmower does not move forward when in drive
Check the drive belt and pulleys. Make sure the belt is tensioned when you release the brake.
Aug 25, 2014 | Husqvarna Garden
Whining sound
check the oil level
Jun 21, 2014 | John Deere Garden
Connected a battery wrong and now Husqvarna YTH20K46 will not crank
look for a blown fuse there taped to the harness
Jun 02, 2012 | Husqvarna Garden
Husqvarna riding mower. Wont start.
check your switch for your blades take it off(shut it off)
Sep 05, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Garden Logo
744 people viewed this question
Top Husqvarna Garden Experts
J. Bradshaw
lnbn1975
Marvin
Marvin
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
