Im trying to change the java limiter that is 500kb, the code that i need to use is *#52828378# , but its not working.I found 4 codes: 1) *#9998*5282# works 2) *#9998*4678255# works 3) *#9998*52824678255# works 4) *#52828378# dont work only the one i need is not working, when i type it not happens,my Cellphone is "Samsung S3500"
SOURCE: phone lock code-samsung s3500
try this code removing your sim card . *2767*2878# . i dont know if it will work on the new models , but there is no harm in trying.
SOURCE: my pc is not detecting my samsung s3500 mobile .i
Dear,
The problem can be with your phone. By the way, check it with other pc. If problem persists then u have to check your phone set to a mobile expert at repairshop near you.
good luck....
SOURCE: when i am trying to open .jad files in my samsung
Get any JAD to JAR converter and use the original JAR files.
SOURCE: unable to run games on samsung s3500
I had the same problem on my s3550. And now i found out from myself what the problem is. I Assume you have memory card and u are trying to install the games from the memory card. That is the problem. Just copy the game you want to install into the telephone memory and install it from there. It will solve your problem. I am so happy to help you. i hope you see this.
SOURCE: what is the unlocking codes for my samsung s3500
Please use one of the below Samsung secret codes to format your phone:
There are actually two codes that you can actually use to
reset the password. Below are these codes. Please dial them
up and have the problem solved.
*2767*3855#
*2767*2878#
Through this mean the security code will be reset to 0000.
This will allow you to format the phone easily.
