Sewing Machines Logo
annie watt Posted on Mar 17, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a brother model 385 1551600 serial 03024885 I have not used it in about 3years. My problem is when i start to sew it will stich maybe a inch then the thread jam up in the bobbin area i'm th
Debbi's Sewing Machine Repair
Level 3:
  • Brother Master 7,365 Answers
  • Posted on Mar 18, 2012
Brother Master
Level 3:
Answers
7365
Questions
Helped
1741560
Points
19451
Change the needle
clean under the needle plate area & in bobbin area for loose threads & lint
make sure the thread isn't coming off the thread take up lever
since the machne has not been used in about 3 years it may need to be serviced
5 Related Answers
radcal
  • 196 Answers
  • Posted on Feb 19, 2008
SOURCE: Designer 1
Please, take this machine to an authorized technician before you attempt to set the timing on your own. An authorized technician will have a device to quickly tell you whether or not the timing is incorrect. If you change the timing yourself and that isn't your problem, you will spend far more money getting 2 problems fixed than the one original problem.
If the machine is making what I describe as a chattering sound, you may be able to clean the bobbin case and the ledge that it sets on and the problem will go away. This bobbin case should be operated with no lubrication. Some repairmen recommend " a drop of oil to make it run quieter". This generally makes it chatter louder. If there is any lube on the bottom of the black bobbin case, wipe it off and wipe the ledge that it rests on.
By the way, if the needle is hitting the raceway, you will be able to see the marks where it is hitting. In a Viking machine, this is normally caused by the "needle to hook clearance", not timing.
Anonymous
  • 87 Answers
  • Posted on Mar 18, 2009
SOURCE: Upper thread knots up with bobbin thread when sewing a stich
Thread test
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test, then let me know, we can go to step 2. If not, try different spool of thread, same test until you get a smooth pull (tip: always check your thread this way when you thread your machine)
Step 2:
Pull on your threaded bobbin thread while it’s in the machine. Does it pull smooth and even? If so, go to step 3. If not, try a new bobbin (bobbins get bent or distorted if wound too tight).
Clean thoroughly in the hook and bobbin case area and oil 1-2 drop is all.
Thread knotting on the bobbin can be a lot of things but here's some guidance:
Tension:
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on toip and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension)
Jamming bobbin case:
If it is damaged from turning out of place once, it could have rough spots on it that makes the thread hang on it, and keeps making it turn over and over. Use a finger nail board (fine sanding) and smoothall rough spots. Then reset the bobbin case taking care to put the notch in the bobbin case in alignment with the proper spot in the machine (basically 5 o’clock) when looking at the round area where the bobbin case goes.
Anonymous
  • 65 Answers
  • Posted on Apr 21, 2009
SOURCE: I have a white sewing machine Model 622 Serial
You can purchase that instruction manual here:
http://www.sewingpartsdirect.com/white-model-622-instruction-manual.aspx
1mrchris
Christopher O'Clair
  • 15 Answers
  • Posted on Jun 15, 2009
SOURCE: I cannot figure out how th re- thread the bobbin.
http://www.tandtrepair.com/700_TanS_Items.html The second link in the 'free items' is Bobbin Winding. I would have typed this all out for you, but since tandtrepair has it all laid out with pictures I figured I'd just link you to it. Hope this gets you back up and sewing.
Anonymous
  • 96 Answers
  • Posted on Dec 13, 2009
SOURCE: needle will not pick up bobbin thread when sewing
double check the upper and lower tensions they often need to be changed to suit types of fabric and threads
Brother sewing machine model AS1430S not picking zig zag stich....on zig zag stich option it is only giving straight stich.....plz help
Try a brand new needle. If that doesn't work, then the machine may be slightly out of time. Search for sewing machine timing or take it for service.
How do i get sewing machine to stop showing code 6 when I have done everything by the book. sews perfect stitches for about an inch then code 6 and locks again?.
Since it is a computer,maybe try unplugging for about a minute and plug back in and turn the machine on. See if the code is cleared. hope this helps
Which stich to use on strechy material
Straight stretch stich is best or small zig zag
Handwheel won't turn, take-up lever not accessable
Make sure the bobbin winding settings are "in-active" - this could be the position of the pin for the bobbin or the center knob on the handwheel, depending on the model you have.
Open the throat plate and bobbin case to be sure there aren't any threads tangled there. This can stop the handwheel from turning.
The bobbin thread will not loop up tight and catches the top thread on LS1520
When you first start to sew turn your right wheel by hand to take up the bobbin thread to the top of the face plate. Pull the bobbin thread and sewing thread together out for a couple of inches to avoid a jam of thread in your first few stiches.
Sewing stops
I sprayed air into the bobbin area - it just needed a cleaning.
Brother LS-2125 presser foot stuck
i bought a new brother stiching machine ls2125. when i started to stich the same no stiching is coming only the mark is coming. why?
Tension problems (?)
Well, I could have written this. I bought a used model from a repairman about a year ago. I have a Model 537FA and I'm going to throw it out in the rain leftover from TS Fay if I don't find some kind of help. :) I'm thinking it's a tension issue, but I can't seem to find a fix.
Does your tension on your top thread sometimes tighten to impossible to move in the middle of sewing. I know that mine does this and it causes the top thread to break. I don't know what's causing the bobbin mess.
Maybe someone will help us? Please!
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
