Sylvania LC420SS8 LCD TV Logo
Anonymous Posted on Mar 17, 2012
I can`t find a PC BOARD BA8IHIGO4015 - Sylvania LC420SS8 LCD TV
  • Anonymous Mar 27, 2012
    I suspect the tuner board.am willing to buy a used one if the owner of a sylvania
    LC420SS8 Decides to junk it.
Code C94 on toshiba 166?
http://printcopy.info/?l=en&mod=erc&brand=Toshiba&model=e-Studio%20223&code=C94
Exploded Views and Parts List Free!
Code
C94
Description
Firmware update error: An error message appears when either of the following Main PC boards is installed to e- STUDIO223/243. - The Main PC board for e-STUDIO181/211 - The Main PC board for e-STUDIO163/166/203/206
Causes
Remedy
Check the MAIN board. A C94 error message appears when either of the following Main PC boards is installed to e-STUDIO223/243. • The Main PC board for e-STUDIO181/211. • The Main PC board for e-STUDIO163/166/203/206.
Toshiba Studio 223 Error Codes
Looking for pc board
Like a computer key board or a brain/circuit board that runs a computer? Or does pc mean something else?
bc you can buy a pc circuit board online depending on the brand of computer. Try eBay,craigslist,even Facebook groups. Good luck :)
Where can I find a A1300319A Board. Because the tech took the board out, and said something wrong with the board.
customer care support SERVICE number+1-
-833'''272''''0777,,,,,,,,,,,call them
THIS SONY A-1300-319-A COMPLETE PC D BOARD IS DESIGNED TO WORK WITH SELECT SONYTELEVISIONS.
1helpful
How to fix cracked PCI board in a amplifier
If the PC board is a single layer board then you can remove the coating on the printed circuits either side on the crack and then solder a small piece of wire on the printed circuit tracks. This will bridge the printed circuits across the cracks.
If the PC board is a multi-layer board then it is impossible to repair and the PC board needs to be replaces if you can get one. It maybe cheaper to get a new amplifier.
I have a toshiba e studio 3510c that is getting a c580 code. any ideas on how to resolve this issue or what may be causing this to happen?
[C580] Communication error between IPC board and finisher
(1) Check if the specified finisher is attached.
(2) Check if the harness connecting the IPC board and the finisher controller PC board is disconnected
or open circuited.
(3) Check if the conductor pattern on the IPC board is short circuited or open circuited.
(4) Check if the conductor pattern on the finisher controller PC board is short circuited or open circuited.
(5) Replace the IPC board.
(6) Replace the finisher controller PC board.
1helpful
I have a Raypak RP 2100 R405 pool heater. When I
Yes its faulty PC board.As no Power Coming from the board.Click this link directly to get PC board. http://www.a1poolparts.com/-strse-Heaters--dsh--Parts-cln-Raypak/searchpath/1015892/start/61/total/103/Categories.bok ------------------ To confirm the fault in PC board. Check for exact 24 volts on PC board. One yellow and One Blue wire. --------- For checking transformer check 120/240 volt to transformer(time clock circuit breaker wire connections). Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
LINE STAGE PC BOARD BURNT SANSUI SV29281
A good tech could probably fix that, did it burn a hole or otherwise carbonize the phenolic PC board material? If so replace the board.
You can only get that board directly from Sansui or one of their distributors. If your set is out of production (more than a couple of years old) there is a good chance that the board is no longer available likely get that board from Sansui, there will be no generic replacement for that. There is a safety factor involved here.
If you can get the board then replace it and see what happens. Hopefully it will happily give your more years of service.
1helpful
POWERMATE 6250. REPLACED A BURNED OUT PC BOARD
Usually a bad ground to the board can cause this problem.
1helpful
3answers
Ilo 26" TV stuck on one station and will not respond to buttons.
all you need to do is buy a control board its a 15 dollar part try shop jimmy .com
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
