My Motorola headset is paired to a blackberry and i want to pair it to my razor2 but the device is not being found. How do I pair the H500 headset to my phone?
I believe you have to hold the power button in until the light starts
to blink, then tell your phone to look for the device. Don't forget to
remove the device in your blackberry if you are still using it.
I have a Sprint Blackberry 8830 and a Motorola H500 headset which I no longer have the instructions for. My Blackberry wouldn't find the device. Through trial and error I found that, to pair the headset with the Blackberry, I had to press and hold the call button until it was solid blue, then the Blackberry found it. The passcode is 0000 for this one.
-Be sure the headset is fully charged.(plug it in till the light turns off.) -Hold the talk button down for 4 seconds or until the blue light goes solid (not blinking.)
Now the device should be ready to pair with your Blackberry. It usually only stays in pairing mode for a short while (approximately 90seconds)
Turn the bluetooth off and go into the phone to search for devices, then turn the bluetooth on holding onto the on button until the blinking blue light turns solid for a couple of second then let go. The device should come up on the blackberry as Motorola H500, pair it and enter passcode 0000. Goodluck
The Blackberry Pearl was designed to work with 2.0 model bluetooth handsfree headsets. Whereas the Motorola H500 is compatible with 1.1 - 1.2 bluetooth apps only. I'm guessing you will have to dish out the cash on this one, sorry!
It might already have been figured out but if you hold the answer button on the headset down until the light stays on steady, it is in pairing mode. You can then go to bluetooth setup on the Curve and it will find the headset.
you need to press and hold the on button on the headset, until the blue light stays on, then it will be in pairing mode.
As soon as the headset is paired the blue light will go off and flash periodically.
To turn off the headset press and hold button for about 3 seconds, it will flash 3 times then let go and it will turn off.
