U disconnectd somethin on motor or not tite or greasy. U didnt git gears n othrparts back tgethr rite. Bottom end work is touchy..need rite tools..u gutta clymer shop manual
How old is the heater?
When was the last time it worked correctly?
Does the pool reach the set point? If not, how close does it get?How long will the heater run (hours)?
What model pump are you using?
Hi, interesting question....
If you have access to a large enough solar system, then as long as there is sufficient power from the inverter, it will work as the UPS will consider it is being powered by a mains source.
The amount of power you will need from the SS will directly depend on how much load you have on your UPS.
Remember that you will need enough power from the SS to drive the
1) UPS electronics
2) UPS battery charger
3) Load items
If you haven't done so already,if it is battery operated then try new battery. If it is dual power and uses a/c also then make sure you have power to the unit. Try to remove front or back cover and see if you can find a fuse. If none of the above works then I think you need to replace the control. Thank you.
These pool heaters have a very helpful and easy to follow chart in their users manual for problems such as this one. There are questions that you will need to answer that you cant answer unless you are looking at the heater. Below is a pdf version of the manual.
SORRY YOU HEATER IS GONE THE HEAT EXCHANGER HAS ALEAK THIS IS DUE TO POOR WATER CHEMESTRY ,LOW PH, OR SOMEONE USING TABLETS ON THE SKIMMER THIS DAMAGE THE METALS ON THE HEATER
According to the manual I have, that is a site wiring fault. It means that there is no ground on your AC line coming into the unit.
If you e-mail me, I will send you the pdf of the manual.
Dave [email protected]
