Question about Panasonic RR-830 Desktop Cassette Transcriber / Recorder
Speaker problem Hi, the speaker won't stop playing the sound even when I have a headphone plugged into the monitor jack. It says in the manual that the speaker should be cut off when the monitor jack is plugged in. Anyone knows how to fix it? Thanks in advance.
  • 145 Answers
The headset jack is broken and needs to be replaced.
Posted on Nov 08, 2008
SOURCE:
Looking for old Logitech S-100 driver
These are analog speakers and do not need a driver. First, make sure they're plugged into the speaker/headphone jack and not the microphone jack. Second, make sure the computer's sound output is enabled and set the headphone/speaker jack. Third, verify that the sound output is working by plugging in a headphone set or a different pair of speakers. If the computer sound checks out, the speaker cable is bad or the power supply is not working.
Nov 14, 2017 | Dell Computers & Internet
HOW DO I GET SOUND ???
Your HP Pavilion F1903 monitor does not have built-in speakers. Your desktop computer probably did not come with speakers. You will have to plug computer speakers into the audio-out jack (green) on the back of your computer to play through external speakers.
There are also a number of USB speaker systems available that use USB both for power and for the audio signal.
Alternatively, there is probably an earphone jack on the front panel of your computer. If you plug headphones into that you should be able to listen on your headphones.
Amazon com AmazonBasics USB Powered Computer Speakers A100 Computers... Amazon com Joylive White 3 5mm In Ear Earpiece Earbud Headphone Earphone...
Jun 27, 2016 | HP Pavilion F1903 19" LCD Monitor
Sound stopped playing through speaker
Return it for replacement/repair.
Aug 06, 2015 | VIA Computers & Internet
Internal speakers won't turn off when external audio is connected
Normally , you would expect the TV sound to stop when headphones are plugged in. Obviously not in this case. If you have a set of headphones, try them and see if the TV still has speakers on. If it does, then there may be a setting on the setup of the TV to get headphones to work. If the TV speakers stop, then I would think that the Logitech are not compatible with the TV. The only other thing would be is to get into the TV and disconnect the TV,s own speakers. If the wires are soldered on and not terminal connected, carefully cut 1 of the wires off near the speaker. If 1 wire is cut, the speaker wont work. Make sure both the TV and the additional speakers (If they have their own power supply) you are using are unplugged from the power before you go doing this...!
May 26, 2015 | Haier L32F1120 32-Inch LCD TV 720p 32"
Headphone jack not working
I find that there is a problem with your headphone speaker.
Try with some other headphone, even if it is not working, then you need to take it to the service center.
Cheers,
Mr.Maduraikaran.
Jan 10, 2012 | Acer Computers & Internet
Headphone Jack Problem
Go to the icon tray and double click the speaker icon. Have a look in the Advanced controls to see if you have taken the mute off the pc speaker. There might also be an option to play sound on the pc speaker simultaneously with the headphones. If so, uncheck the dual play box so the sound will not play through the pc speaker when you have the headphones plugged in.
Aug 06, 2009 | Acer Aspire One D150-1587 Netbook
I purchased a used Palm it works fine but I have no sound for calendar alerts. I can't even play the alerts to see which one I want. Can this be fixed.
If you plug in headphones, do you have sound in them?
If so, then the problem is either the built-in speaker or the headphone jack.
If it's the speaker, then you're in for a pretty involved fix involving soldering little tiny wires. Do-able, but not for someone just learning how to use a soldering iron.
If it's the jack, then you might get lucky and fix it by inserting and then removing your headphone's plug.
I've had this style of jack get a bit of dust in it before, and basically think headphones are plugged in even when they're not.
Let me know if you've got sound in headphones, and we can take it from there.
Jul 16, 2009 | Palm Tungsten E2 Handheld
Trying to add speakers
The only way i can see of feeding two sets of speakers from the one pc would be to buy or make up a "splitter" audio lead .....i.e a 3.5mm stereo jack on one end connected to the pc with two lots of wiring going to 2 3.5 mm jacks. I don't know whether a store like Maplins would sell such a lead. Are you any good with a soldering iron??
Dec 31, 2008 | Gateway GT5468 Desktop PC
C785TU problem related to sound
When you plug the headphones in what happens is that inside of the jack the internal speakers  are disconnected and the sound goes to the headphones. If both are playing either the jack is not inserted far enough or  female plug is loose or defective.  Replace or repair the female plug.
Dec 18, 2008 | Compaq Presario Notebook
No Sound in any mode
I had the same problem... but I knew that my 2 yr old had been playing with the headphone jack on the BC-150. Evidently, the system thought that headphones were still plugged in to the port on the front right of the unit, even though none were present. The solution that worked for me was to take some headphones, plug them COMPLETELY into the system (another set of headphones would not insert all the way, so I found a new set and used those to completely insert into the headphone port) while playing a CD and listen for a few seconds and then simply unplug them. Viola! Sound came back. Hope this helps.
Dec 24, 2007 | Sony DAV-BC150 System
Panasonic RR-830 Desktop Cassette Transcriber / Recorder Logo
71 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
John Wardlow
John Wardlow
Level 1 Expert
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
