Yeah i turn up the volume to past about 12 and it shuts off
The problem is in the audio output ic, or bad solder contacts, check to make sure there are no bare speaker wires showing, and if by chance you added additional speakers, then that is the problem and should be removed.
Testimonial: "hey there John! thanks so much!! I just went to the back of my stereo and pushed in the speaker wires in a bit more and there's been no problems ever since! I also fixed my extended wiring, i have two speakers that I have extended with extra speaker wire, but yeah my stereo was working fine even before i did that, it was simply a matter of putting them in right on the one side- the wires for the one speaker was really poked in all the way! Thank so much again John!! Saved me a trip to the repair shop!! I'm recommend this site to all my friends!!"
SOURCE: stereo goes into protect mode
Protect is a safety feature so that you do not blow your speakers. However with it hooked up with the computer you may have surpassed the max output. If it still does this with out going through the computer, it has been damaged.
SOURCE: Hey yeah ummm when my like stereo is off I can con...
SEEMS LIKE YOU ARE TRYING TO PLUG INTO THE HEADPHONES JACK AT THE FRONT ! NO GOOD . YOU NEED TO HAVE STEREO ON. AND USE AUX. TO DO THIS pLUG IN YOUR MP3 PLAYER WITH 3.5 STEREO JACK OTHER END BACK OF STEREO INTO AUX. RED AND WHITE RCA PLUGS.
THIS LEAD COSTS LESS THAN $7.00 AND THE SOUND IS VERY LOUD THEN. !
I DID IT MYSELF AND AM HAPPY WITH IT .
Stereo begin to shut off when I increase the volume past 14 or15
