Refrigerators Logo
Posted on Mar 16, 2012
Samsung rs2530 screen went blank except 1 lights bar flashing on freezer and wont cool
Anonymous
Level 1:
New Friend:
  • Contributor 6 Answers
  • Posted on Mar 16, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
6
Questions
0
Helped
4473
Points
12
The one light flashing on the display is an error code. Depending on which light is flashing will tell you what the error code is. Check the link below to see if it has the error code. That should give you an idea of where to start.
Samsung Error Code List
5 Related Answers
adnanbhatti
Adnan Bhatti
  • 1188 Answers
  • Posted on Aug 07, 2009
SOURCE: my side by side samsung RS2530 bbpfreezer is not freezing any ice
Are you taking too much ice in too short time? The freezer needs some time to freeze the water to form cubes. Another reason is that the water supply line may be blocked by air bubbles. Ensure that the water supply is adequate.
Anonymous
  • 74 Answers
  • Posted on Aug 28, 2008
SOURCE: GE Profile Artica
The main PCB at the back of the appliance has failed
Anonymous
  • 212 Answers
  • Posted on Jun 24, 2009
SOURCE: Freezer light flashing
if you have ice built up on rear wall of freezer section then your unit is not going through defrost cycle which builds up frost on evaporator and restricts cold air flow over to the fresh food side.
Anonymous
  • 65 Answers
  • Posted on Sep 14, 2009
SOURCE: rs21 samsung twin cooling
These usually have one compressor and an evaporator on each side with a fan. check the fans first then the defrost timer, heater and limit thermostat.
Anonymous
  • 117 Answers
  • Posted on Sep 21, 2010
SOURCE: samsung not cooling
this
samsung diy video guide may be of help
lots of usefull info , sounds like you ahve an ice maker unit fault which can stop whole f/f from working
Samsung RS2530 B...flasing green light on freezer side will not turn on...
sorry but i hate the lg and samsung products. they have some unusual error codes. a flashing light doesnt describe enough of what is happening. try doing a google search for samsung error codes and then get back on here with the actual error code and maybe i can help from there.
My kobo wont turn on
Try this, it worked for me
Turn off phone
Remove battery
Wait 10 seconds
Plug in charger
Insert battery
Turn on phone
Dec 12, 2017 • iPhone Apps
My side by side samsung RS2530 bbpfreezer is not freezing any ice
3helpful
2answers
Display problem
If formatting your phone doesnt help there are three possible problems in order of priority (1) your screen is gone and needs replaced (2) your ribbon cable is gone and needs replaced (3) phone needs flashed, I have repaired the first two above on many samsungs with this fault! Not an easy job! Hope this helps.
Refrigerator stopped working
ok whats the light that you see? i need to know what the bars are and or your email and i can email you the list for the codes.
Km1 screen blank
You need flashing your phone. Power off your phone. Press * and # at the same time and power on your phone while pressing those keys. It supposed to show your phone information. If it shows, notice the phone software version. Search on google and download that version flash file. For flashing you need RSD Lite or Flash&Backup software. Search on google also for these. Additionally, an USB cable is needed to flash the phone.
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
