SOURCE: my 2001 Chrysler 300m idles very high and will not
Either a cracked plenum or bad plenum gasket.
SOURCE: how do you remove the rear seat in a chrysler 300M
Grab the bottom seat cushion at the front of one side and pull it straight up then do the same on the other side. (you will have to pull up very hard) The bottom of the seat clips in. once you have the bottom out take the 2 bolts out of the seat belt fasteners that holds the bottom of the top seat cushion. Then pull straight up on the seat cushion to slide it off two tabs that hold the top.
SOURCE: R & R Fuel Pump on a 2001 Chrysler 300M
Removal & Installation
The in-tank fuel pump module contains the fuel pump and pressure regulator which adjusts fuel system pressure. Fuel pump voltage is supplied through the fuel pump relay. The fuel pump is serviced as part of the fuel pump module. The fuel pump module is installed in the top of the fuel tank and contains the electric fuel pump, fuel pump reservoir, inlet strainer fuel gauge sending unit, fuel supply and return line connections and the pressure regulator. The inlet strainer, fuel pressure regulator and level sensor are the only serviceable items. If the fuel pump requires service, replace the fuel pump module.
Negative battery cable
Fuel tank
Fuel lines from the fuel pump module by squeezing the quick-connect fitting with thumb and forefinger
