Solly Sally Posted on Mar 16, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the reset button on di3510f - Minolta Di3510f Bizhub Copier
Norman Weimar
Level 3:
  • Minolta Master 7,035 Answers
  • Posted on Feb 18, 2015
Norman Weimar
Minolta Master
Level 3:
Answers
7035
Questions
Helped
1913587
Points
11960
For what are you trying to reset?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
How to fix a cobao error on a DI3510f multifunction printer
COBAO - Elevator motor ascent/descent drive failure.Remove the finisher unit and work without.
1helpful
C0500
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
Di3510 password reset
utility /counter
meter count stop 00 stop01
select administrator to reset the password.
No message c0070 error but the motor does not move
There is no such code for the Di3510F. What is the correct model?
How do I scan from my Bizhub Di3510f to my computer?
You need to go onto the user interface of the machine and add your network settings. this is done by entering the IP address into your search bar and then going to have to enter the details into the relevant boxes
I can't print with my di3510f
Is this a network printer? Can other computers print? Are the drivers installed? go to below web site to ensure you have the correct drivers
Self Help Product Support Konica Minolta Business Solutions Inc
1helpful
Looking for mac print driver for konica minolta di3510f.
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productname=di3510f
My dialta di3510f is almost 3 years old and has not been used in the past two years...about how much is it worth?
Depending on condition and options...about $1,000. I sell these on a regular basis and I get a little more retail but that is with a warranty.
Minolta Di3510F indicated malfunction error with code COBAO. Can anyone help?
COBAo = Elevate mechanism malfunction.
The exit tray home position sensor is not blocked even after the lapse of a given period of time after the tray has started moving up.
An encoder clock input is not detected within a given period of time during operation of the tray.Check the sensors,motors and his connectors.
How to reset:
1. Press the trouble reset switch on the Tech.Rep.Setting Switches Board to reset the following malfunctions:scanner,fusing,exposure related malfunctions and C3FF.
2. For any other malfunctions open and close the front door or turn OFF and ON the power switch.
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Daniel Blask
Daniel Blask
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
