SOURCE: Won't start.
There is a reset button at the back of the powerhead. The user manual can be downloaded from the electrolux website, although I didn't find it very useful. There was some info on how to change the powerhead drive belt.
SOURCE: Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
SOURCE: Full bag system works properly, but doesn't reset easily
Either there is something wrong with your switch. Which it doesnt sound like it. Take it to your dealer or call another one it sounds like the control valve needs to be replaced. I am a dealer 1-866-966-9350.
Im going to guess you have an Electrolux Tank. the control valve inside probably went bad. normally i just disconnect it. Do no try to take it apart if you don't know what your doing. take it to a vacuum shop.
SOURCE: while vacuuming the red light
I'm assuming this is the Epic 6500 or similar model.
Detach the hose, turn vacuum on. If it runs, place palm of hand against inport hole. If it shuts off the problem is with either the control valve setting or the control valve assembly itself.
For cvs, turn dial on top of vacuum all the way to the largest dot, and try above test again. If that doesn't work, then it's the CVA. It needs to be cleaned or replaced, which is an in shop job. Fro repair, take it to the nearest Aerus Electrolux store. I recommend a full clean and service to remove any dust/dirt from the motor, fan assembly, and other internal parts.
Another problem, which relates to the dial setting, is that fine dust will quickly clog the pores of the bag, resulting in the machine "thinking" the bag is full. Turning the dial to the proper setting helps get the bag fuller. The middle setting is the normal setting, and is for areas without fine dust and sand.
