Polar AXN 300 Watch Logo
James Brown Posted on Oct 03, 2006
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
AXN 300 Watch
I have just received a Polar AXN 300 Watch which I bid for on Ebay. Apparently new. However the display shows "Error 0". I cannot remove this, even taking the battery out and replacing it. Can anyone help me on this. many thanks in advance
  • Anonymous Mar 26, 2014
    i need to find a replacement watch band for my AXN 700 POLAR WATCH
Anonymous
Level 3:
  • Master 944 Answers
  • Posted on Apr 20, 2007
Anonymous
Master
Level 3:
Answers
944
Questions
Helped
786897
Points
2417
Here is the link to the user manual for your watch; http://www.polarusa.com/manuals/AXN300.pdf Check page 9 - you have to re-enter these basic settings after removing the battery, this may clear the error message although i was unable to confirm this from the manual. contact polar on; http://www.polarusa.com/default.asp and you can find a service centre who can check your watch, all the necessary link software downloads etc. Hope this helps :)
Peter Morey-Weale
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 03, 2013
Peter Morey-Weale
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
467
Points
Throw the wretched thing away and buy another make. I've had mine repaired and exchanged 4 times and find the service centre here in France unhelpful, expensive and rude. I would not buy another Polar product again.
Where can I find a new watch strap for my Polar AXN 500
You can get these directly from Polar. www.polarusa.com or www.polar.fi
Polar F6. After the new battery installed the display is very weak - allmost invisible. Battery is the same type and new for sure. Othervise it works just fine. Beeb sounds are strong and everything. Just...
I had the same problem, the screen would be sharp when adjusting setttings after battery-replacemnet only to fade as soon as seconds after startup.
In my case the solution was to dissasemble the watch, use a toothpick or whatever to remove dirt from the copperplate lines (three long lines and one short line) that connect the hardware-part of the watch to the screen (the backside of the screen has lines that correspond to that of the copperplate lines on the frontside of the hardware-part).
Hope this helps, it worked out great for me!
How to use the heart rate monitor
Thank you for contacting FixYa.
You can contact Polar here:
http://www.polarusa.com/us-en/
Best regards. Jewel
1helpful
Ive just had a new battery in the watch and went to exercise. The watch doesnt seem to pick up my heart rate it keeps displaying 00. Any ideas?
You have to sync your watch. Browse through my tips and you will find link for manual for your POLAR watch.
I cracked and chipped the glass of my axn500 watch. what do i have to do?
You can go to a watch repair shop and have the crystal replaced but since it is a sport watch and has a good water resistance rating I would make sure that wherever you go can pressure test it to be sure it is resealed properly. Your best bet is to go directly through Polar for the repair or replace the watch depending on cost.
Polar F4 monitor is reading about 30bpm less than actual
Check that the case back is on the right way. A spring sticking out of the watch mech needs to line up with a hole in the white sticker on the inside of the case back, I think this is the receiver aerial.
3helpful
Error after changing battery in polar watch
Follow this link:
http://www.polar.fi/en/support/product_support?product=125
This is original Polar support site.Here you will find all the info available.
Rate me, please.
1helpful
Heart Rate monitor not working
Follow this link and download complete manual;
http://www.polar.fi/en/support/product_support?product=275&category=Downloads
Rate me, please.
Top Polar Watches Experts
NOEL
NOEL
vince
Alex Kimuyu
Are you a Polar Watch Expert? Answer questions, earn points and help others
