my duplo copieris displaying eror code e001 and does not allow me to make copies from it. help pleasemy duplo copieris displaying eror code e001 and does not allow me to make copies from it. help please
You can't post conmments that contain an email address.
<quote> How to reset E000, E001, E003 and E007 Canon IR2016, IR2020
Enter the service mode by pressing "additional function" key, "2" and "8" keys in that order. SSSW will display. Press "OK" key.
Change Bit switch 1, bit 0 (might display as the first one on the left using number keys) status, (change 1 to 0 or 0 to 1).
Press "OK" than Press "Stop" or "Additional Function key" to end service mode or restart the machine.
</quote>
Title : E001 Error Code That is Not Resetable Error : paper jam When the machine powers
up the E001 error code is displayed but cannot be reset. (Note: The reset
procedure for an E001 code is COPIER>FUNCTION>CLEAR>ERR) Workaround
: In this case, the Main Power Supply PCB Assembly was replaced. The machine
was powered up and the E001 code was able to be reset. The part number for the
Main Power Supply Assembly is FM2-0260-000. Remember, if the fixing unit
circuitry has an open or a short, the code may not reset. Be sure to confirm
the fixing unit wiring and try resetting the code before replacing the Main
Power Supply Assembly. Canon USA, Inc. Systems & Technical Support
Division1-800-528-2830
uhm i know that the reset function helps when on the control pannel display is displayed with the error code E000, but what was said from the noise the copier makes when it copies, i would say that the pick up paper assembly, will stop working, if u have other trays in your copier, try coping from there and see if it makes the same noise, if not..then probably, u have to replace that part soon " pick up paper assembly" am not an expert, but i also have one, and some things i've seen with it:)
Your in luck, Canon really did not change there error codes from way back then..... A E001 means you have a problem with the fusing unit. You may have a blown thermal fuse or one of the heatting lamps or you may have a bad thermister. It may be one or all of them. Did you try to rest the error code?
That means that you have fixing error.Try next: press MENU and #, with cursors go to clear, press ok, select err or all and ok. If the problem was only fluctuaction in temperature the machine would work normally. If not call service, because you have problem with heating lamp, or thermistors, or...
hello there here is some information that may help you solve this problem ok? best regards michael
Printer Repair And Service Tools: Ir3200 error code e000677-0004
Canon Multi-Pass Fax C855 waste tank resetcode... Canon Error Code, E000, E001,E002,E003,E004,E005. Ir3200 error code e000677-0004 ...indoresetter.blogspot.com/2009/02/ir3200-error-code-e000677-0004.html - 82k - Cached
C3200 Problem Solving at FixYa
how do I reset this code? canon ir 3300. 1 Solution. after pressing *28 it come download mode ...e005 an error canon 6330. the quality of four colour is very ...www.fixya.com/tags/c3200 - 89k - Cached
E004 Problem Solving at FixYa
along with e001 and e005... HP Pavilion dv2000t PC... Problem Event Name: APPCRASH ...codes with this model np 7161 e004 iwant to know how to get in reset program...www.fixya.com/tags/e004 - 92k - Cached
The Copier Network - Canon 6085 E5... what this code means or howtoreset it any suggestions? ...E005 is fuser web out. clear web counter. techla. I replaced the web just coundn't resetthecode. ...www.thecopiernetwork.com/printthread.cfm?Forum=87&Topic=18014 - Cached
The error can be cleared in the service mode. Contact Canon Consumer Products 800-828-4040
Press Additional Functions key Press # Press > to #7 Printer Function Press Set Press > to #4 Printer Reset Press Set Press < Unplug printer and repower it.
