I have the above split open. Two problems have occurred. I have browsed for a parts blowout plan but no luck.
First, a spring suddenly popped out and is approx. 1" long. I think its for the squeeze trigger on the handle but cant see where it goes.
Second, the bushing on the bottom side, [looks a bit like a hat with no lid] also fell off. I have put that back on and it slots in well. It does not appear to fit the other way round. Is that right? Thankyou for any help.
There is a small protusion in the plastic of the handle that acts as a seat for the spring. If you look carefully it is suddemly very obvious. The same is true with the soring for the upper handle.
You can try www.toolpartsdirect.com/bosch/bosch-40.html and in the search box enter your model numberand hopefuly that will help you on a break-down for your machine. Your welcome in advance if it worksif it doesn't let me know and I will need the model # and serial # and I will look again for you.
