Motorola Mobility MOTOROKR T505 Logo
Posted on Feb 07, 2018
Voice prompt works first time then quits
I am trying to program my T5605. I scroll through setup. and turn v oice prompt to "on." The first time I receive a call the voice prompt gives me number calling. However, that is as far as it goes. The next calls just ring and do not identify the number calling. Please advise.
1 Related Answer
vqcb43
Motorola Mobility
  • 1623 Answers
  • Posted on Mar 09, 2015
Mobile Phones and Acessories
    Verified Fixya Pro
    SOURCE: when making a call, I get a message that says, your account is not authorized to make calls to this number. I also receive calls
    J olive
    What is the number? Only one number or all numbers? Do you have a call restriction set to only allow calls to certain numbers?
    Mark
    Motorola Support
    2helpful
    5answers
    How to disable voice prompts on ipad ?
    Settings > General > Accessibility > Voice Over > Off
    This is in the Vision section and is intended to assist the visually impaired.
    tip
    Toshiba Laptop BIOS Password Removal
    <span><b>ESC Key BIOS Password removing procedure</b><br />1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key. The computer will display the "Password = " prompt.<br />2. Enter the correct password, and press the Enter key. The computer will display "Valid password entered, system is now starting up. Check system. Then press (F1) key"<br />3. Press the F1 key. The BIOS setup program will appear.<br />4. Using the arrow keys or the tab key, move to the password field, and highlight REGISTERED.<br />5. Press the spacebar, enter the correct password, and press the Enter key. The Password field will change to NOT REGISTERED.<br /><b><br />F2 Key BIOS Password removing procedure</b><br />1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key. The unit will display the "Password = " prompt.<br />2. Enter the correct password, press the Enter key. (You may need to press the F2 key after you hit the enter key.)<br />3. The BIOS setup program will appear.<br />4. Using the arrow keys, move to the Security tab, and to Set User Password.<br />5. Press the F5 or the F6 key to navigate to the Password section. Enter the current password at the Old Password prompt, and press Enter. At the New Password prompt, press Enter (without typing anything into the password field). At the Confirm Password prompt, press Enter again (without typing anything into the password field). The password should now be removed.<br />6. Press F10 to save and exit from the BIOS Setup program.<br /><br />In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.<br /><br />If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.</span>
    on Jun 09, 2011 • Computers & Internet
    tip
    How to Erase RegCure from your pc system
    <span><span> <p>RegCure is a registry repair tool that allows you to solve registry errors, such as missing dll files, damaged registry keys and corrupt settings. If you are no longer interested in this program, or prefer to install and use a different registry repair tool, uninstall RegCure from your<span> </span><a href="http://www.ehow.com/computers/">computer</a>. Uninstalling RegCure is a quick and simple process for Windows 7, Vista and XP users.<span></span><br /><br /><span></span> <span>Instructions</span> <ol> <li> <ul> <li><span>1</span> <p>Click the "Start" menu and then click "Control Panel." Click "Uninstall a Program" if you are using Windows 7 or "Programs and Features" if you are using Vista. Double-click "Add or Remove Programs" if you are using Windows XP. The programs window will launch.<br /></li> <li><span>2</span> <p>Scroll down and click "RegCure." Click the "Remove" or "Uninstall" button. If prompted, enter your administrator password and confirm you want to remove the application. The setup wizard will remove the program.<br /></li> <li><span>3</span> <p>Restart your computer to complete the process<br /></li></ul></li></ol></span></span>
    on Dec 27, 2010 • Computers & Internet
    I am a manufacturing engineer... I want to program my calculator for machining functions. When I program simple equations, such as Surface Feet per Minute, RPM x DIA / 3.82, the prompts are only (?), and I...
    Yes, that is possible. Here is a simple program that prompts the user to enter the value of the radius, then it displays the circumference.
    To name variables use single letter symbols, A, B, C, ...
    To enter keywords such as Input and Disp(play) use the sequence [2nd][0] (Catalog) then scroll or press the letter that begins the keyword to go to the top of the list of commands that start with that letter. For other mathematical and non litteral symbols scroll up to go to the end of the catalog and continue to scroll up until you find the symbol.
    What is "time out" setting in voice prompts
    When you try voice command and you cant speack any thing or sound is not clear than time out will appear If your voice is clear than your command are not found... Just try other word
    Bluetooth
    Did you find a solution to this? I'm having the same issue with my daughter-in-law's 2012 Kia Sorento. The car pairs with her iphone, but the voice prompts don't come up .... it only emits beebs.
    4helpful
    3answers
    I have older Toshiba laptop A15-S1292 running XP SP3. Problem is every time it start, before anything can be seen, it ask for password. I know the password, but I do not know how to romove the...
    How do i program this remote control Radio Shack 6-in-1 Easy Setup Voice Remote Remote Control Easy remote
    Turn on the unit to be controlled manually. Press and hold Setup until the voice prompt starts the programming menu. Press 1 to directly enter a code. Press 2 to search for a code. Note at any step if the no buttons are pressed for 15 seconds, the remote will enter the usage mode. Start again from the Setup button. When prompted, press the device button for the device you want the remote to control.
    Then enter the 4 digit code (if using the direct programming mode). The LED will blink twice and the remote will announce success. Test if the remote works (play, power) when prompted to test the code and press Setup if it is successful. Then wait until the remote says goodbye and then press Power again. The unit should turn off. (I strongly suggest testing other functions as well after this.) Repeat with other codes if unsuccessful.
    For searching through the programmed codes, start as indicated above: press and hold Setup and then press 2. When prompted press the device button. Then press the test key (power usually). Slowly alternate pressing CH+ and power until the device turns off. Press CH- if you miss the device turning off. Press Setup to store the code. Then after the remote says goodbye check if the remote works for all the functions. Repeat the above if it doesn't work for all features.
    The manual for the remote is available here: http://files.remotecentral.com/view/852-1041-1/radio_shack_15-2146_6-in-1_easy_setup_voice.html . This file is a PDF in a zip archive and does include the code list at the end.
    Please note that codes in the remotes are limited to those for devices released at least 6 months before the remote was programmed. If your device is newer than your remote, you may need a new universal remote. I suspect this remote may be from 2004.
    I hope this helps.
    2helpful
    How do I activate the voice dial on my Nokia 6230i please?
    At the menu screen,select menu and scroll down to contacts, hit select,then select names, find the number you want to add voice dial to, select details,select options,scroll down to "add voice tag" Hit select and follow the instructions.
    One tip: when you program the voice call, you should be in the enviroment thet you usually use the voice dial. If you set it up in a quite place like your home and then try to use voice dial in a noisy place, it probably will not work. Also talking louder does not help.
    Hope that helps. If not, you probably have a problem with the phone itself.
    Latre....
    Delete old voice mail - program new voice mail
    You can usually access the system voice mail setup from any extension.
    Press Speaker
    Dial ext 200.
    When asked for security code, dial *,2,# (dial it twice if there is no code).
    When main greeting begins, dial 632.
    Using the soft keys under the display, press MORE, then MGR, then CHBX or, follow voice prompts if non-display phone.
    Follow voice prompts. Remember, 1=Yes, 2=No.
    Top Motorola Mobility Cell Phones Experts
    AFIFUL HAQUE MUFTI...
    Level 1 Expert
    vince
    john h
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
