SOURCE: camera wont turn on...gives beep sounds and green light glows when pressing power button
Does the lens extend in either of these cases? If there has been some malfunction in the lens and it fails to extend the situation can cause the camera to power-off in order to protect itself. Some cameras show error messages before powering off, others do not. Hold the camera up to your ear and turn the power on. Is there a series of mechanical sounds before the beeps? Hearing sounds but not seeing the lens extend indicates some sort of failure in the lens assembly. If you hear nothing then the problem most likely lies elsewhere, possibly a failed electronic component or something as simple as a loose connection. Check with your manufacturer for any recalls or technical bulletins, and see if they will service your camera under warranty. If not there are a number of repair facilitys available on the internet who generally have better rates than out-of-warranty service at the factory. David Millier Advance Camera Repair
SOURCE: Samsung L200 Digital Camera
I took it to a camera shop. It cannot be fixed.
Your guy probably figured that out too. He kept the line open for 2 hours before I finally closed the screen. I really don't think his 5 minutes should cost me 14.95.
SOURCE: GE A830 digital camera
It would rust the metal and solder points in the camera and probably dilute the grease in the gears.
Call: General Imaging Europe Ltd
500 Avebury Boulevard
Milton Keynes
MK9 2BE
Phone: +44(0) 1908 547969
Mobile: +44(0) 7824 991875
Email: [email protected]
SOURCE: nikon service centres in bangalore india
NIKON SERVICE CENTRE IS AT MATA ELECTRONICS, SP RD,NO 86,1ST FLOOR,OPP TO ANKIT INFOTECK.CONTACT MR VIJAY. 9035871324 .080-22130711. BEST SERVICE.
