Washing Machines Logo
Anonymous Posted on Mar 15, 2012
How do we clean with this machine .
We do all the thing whilpool says to do past year and half and still can,t get our cloths clean
  • 1 more comment
  • Anonymous Mar 16, 2012
    whilpool top load wtw5600xwo ,did every thing in solution(1) below and thank you.Got four years warranty and whilpool techs came out four times and just look and never tested nothing ,just say its a H.E. machine and left. call whilpool and they tell me the tech told them it o.k. . never complainted on any thing in my 50 years,but i need water to clean cloths.computer run washer and will paint it yellow and take it to sears down town Mobile , al
    just need help thank you..
  • Anonymous Mar 17, 2012
    What can I do to make my clothes get clean and not have sweat stains under the arms of my shirts and not have an odor in them after washing and drying ? I have already tried cleaning the machine with Affresh once a month and even cleaned it with bleach and hot water 8 days in a row..nothing has helped!!!!
  • Anonymous Mar 20, 2012
    For the sweat stains, you could try Resolve Stain lifter. Pre spray before washing. you can add it during the wash cycle also. A can of cola can be useful for removing a lot of different types of stains. I used it for removing hydraulic oil from my work clothes. You may need to soak your clothes with the cola for an hour or two. Try using Gunk hand cleaner on the stains (mechanic hand cleaner). Dawn hand soap is really good at lifting oil and grease. Just make sure you rinse the Dawn out before you wash the clothes because it will make a LOT of Suds.
    Do you have hard water, or is there a lot of sulfur in your water? Water softeners can sometimes help, but sometimes these aren't enough. Iron in your water can definately stain your clothes. You can get your water tested at Sears. If you have a lot of pink grime inside your toilet tank, or rust sains on your bathtub and sinks, this may be an indicator that your water has issues. You can get your water tested at Sears for a small fee, and they have a lot of solutions for filtration.
    I know this isnt really treating the problem, but perhaps you can cover up the smell of your clothes with pleasant smelling laundry detergent. I prefer Gain, but anything that smells good to you would probably work ok.
    Im not a big fan of HE machines. I had one a few years ago with similar problems and finally decided to go back to the old top-load regular washer. Have been happy ever since.
Anonymous
Level 1:
New Friend:
  • Contributor 15 Answers
  • Posted on Mar 15, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
15
Questions
Helped
11540
Points
55
Is this a front-load washer or top load?
Is the machine operating properly, or are your clothes getting a musty smell?
The musty smell has a few solutions, One may work but probably a combination of all will work best.
Immediately move wet clothes to the dryer, do not let them sit in the washer for a long time.
If your clothes smell, put mouthwash with your clothes directly in the tub during the wash cycle (this will not stain your clothes)
leave the door open when not in use (lets it dry out)
If the washer smells, use bleach and hot water in an empty cycle once in a while (kills just about every kind of bacteria or mold which may be causing the smell)
Use washing machine cleaner once in a while(can be found at your local grocery store isle next to detergent)
Dry your clothes completely, damp clothes can start to smell again.
If you are looking for a new washer, try to find a newer model that features a stainless steel tub with silver impregnation. The silver is a natural disinfectant.
I have tried and tride many times to clean the system as per the instructions listed on page 24 of the use and care guide. I t has yet to perform the cycle with HOT water as noted and after adding the...
what i usually do to clean the washer for the past 10 years is just to fill it halfway with water and add 2-3 tbsp of vinegar and run it like washing clothes then leave it half-open to airdry.
5helpful
I have my LG Fuzzy Logic for 3 years now. Lately after washing my clothes I see that there is black particals stuck to my clothes after washing. I comes off when I shake the piece of clothing. I has a...
It's just a build up of residue. To clean out your drum, run a hot cycle (obviously with no clothes in the machine) with half a cup of vinegar then when the cycle is finished, wipe out all the residue, and trust me there will be alot. I do this every 3 months to give the drum a good clean out.
1helpful
Model LSE1000 - The washer is getting old and not spinning the clothes as dry as it used too. Am I looking at replacing belts, pumps or cleaning out something that may be causing this problem. The washer...
NEED TO KNOW NAME BRAIND IF WHILPOOL HOW OLD IF MAYTAG REPLACE BELT SAME WITH GE WITH WHILPOOL NEED MOR INFO TO HELP LIKE IS IT SPINING AT ALL OR SLOW IF SLOW MAY BE YOUR CLUTCH OR DRIVE BLOCK IF NOT AT ALL WILL IT AGITAT IF NOT DRIVE COUPLER IN BETREEN PUMP AND MOTOR
1helpful
Hi i have a whilpool 5132E top load washing machine i bought second hand, my cloths collect fluff, especially the towels. Does thi model have a filter.thank you chrissie
no but it sound like the agitator has a sharp edge and chewing up the cloths feel your finger all the surface area of the plastic and feel for a gouge or rough area then get sandpaper or other type of item that will smooth it out and that should stop the fluff issue
1helpful
2answers
The clothes do not come clean!!! I was noticing that my arm pits were very itchy all the time and found that the deoderant was not washing out of the clothes.I probably wouldnt have caught it if it wasnt a...
Ok this is going to sound crazy but we tell all of your customers to use tank (yes the drink that you make for your kids) Fill the tank to the top line on the tank lid and start your hot water just like your going to start a load of laundry and then dump in the tank. The tank has a lot of acid in it and it wll clean all of the lines and make it smell good. We use it in our machine as well. My husband has been a servicer for 28 years. We own our own appliance business. I know it sounds crazy but it works.
Whilpool washers drains but when done spinning puts water bk out
If you have a selection for extra rinces deselect it and try. If not almost certainly your timer is faulty.
3helpful
3answers
6 years old hoover washer dryer. Not all, but some light colored tee shirts coming out with what appears to be oily spots. Tried bleach and dishwater tablet as suggested by another forum, but to no avail....
Hi there monobloc,
I've gone through this too. Dishwashing liquid soap, specifically with grease cutting properties. It does take a few cycles to clean it all out though.
Mike
Lever sticking
Crome over cupper or brass means some cloth between your wrench and the large nuts on E61 group. Carefully - and it opens. CLEAN and clean again! Do not open all cupplings at the same time. Take phopto on details so you get all pieces back./// Olev
Top Washing Machines Experts
john h
