Unlock my phone forgot my password
What is your mobile an model ?
If you forgot the security code you have to reset you mobile....... Its the only way to use your mobile again. After resetting you can enter a new security code again.
If you use nokia or alcatel mobile means visit here Wickedunlock.com for the master reset code service and get the reset code........
SOURCE: Forgot password
Good Day,
Have you tried the default code?
By default the code is the last four digits of the phone number assigned to the phone. However if the code was changed there is no way to retrive it other than taking it to a tech and having the firmware reset.
Good Luck
Hope this helps
SOURCE: how to unlock phone,when forgot password
hit restore factory setting and the old password is either 1234 or the last 4 of your phone number
SOURCE: i have forgot my phone password and i want to
if its not 12345 then it would need to go to a phone shop to have the code reset.
SOURCE: forgot password
http://nfader.su/index.php Give your imei number there. If you don't have your imei number call *#06# from your mobile. You will get a master security code. With this you can reset your password. Try this.
SOURCE: forgot the phone lock password ..
Hi,please dial this code on your phone, *#7370# code.This is a hard reset code,
Thanks and take care
