What function Key do i use to open the Bios It is F10.
Using Computer Setup (F10)
You can only open Computer Setup by turning on the workstation or restarting the system. To access the
Computer Setup Utilities menu:
Turn on or restart the workstation.
Press the F10 key as soon as the monitor light turns green.
If you do not press the F10 key at the appropriate time, you must try again. Turn the workstation
NOTE
off, then on again, and press the F10 key again to access the utility.
Select your language from the list and press Enter. In the Computer Setup Utilities menu, four
headings are displayed: File, Storage, Security, and Advanced.
Use the arrow (left and right) keys to select the appropriate heading. Use the arrow (up and down)
keys to select the option you want, then press Enter.
Goodluck :)
SOURCE: forget bios password
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00530488/c00530488.pdf?jumpid=reg_R1002_USEN
Chapter 1.2
Looks like you'll need access to an authorized service provider.
SOURCE: How to enter to zx6000's BIOS?
You can get the manuals for this product online at HP's site. I am looking at the Operation And Maintenance Guide for HP Workstation zx6000 HP Server rx2600 right now. in .pdf format. but there is nothing in there about this problem. I would suggest downloading it though, 27MB manual with a wealth of information on it! There is also a startup guide. and other manuals.
What OS are you running on this machine? Is it windows or linux?
If you can get to a command line >
sudo /sbin/hwclock --set --date "08/04/2000 08:33:25"
replace the date and time with todays date and time of coarse but I found that little gem of info on the web. I hope it helps.
SOURCE: i have hp dv4-1465dx, how to reset bios without having OS
Was Windows 7 the operating system that came with
your System? If not, What I would advise you to do
is this:
Check HP website to find out if your Laptop supports
Windows 7.
If it doesn't, then I would advise you to
PLEASE change it back to the operating system
that came with your system, or better still, the
operating system that it supports.
The reason is because that is exactly what I faced
two weeks ago....
I changed the operating system for my PC to
Windows 7 ( Even though it doesn't support it)...it
worked fine for a while, then later it started to develop
faults after a while...like stuttering, mouse pointer
moving round the screen, graphics displaying
improperly...etc.
I first thought it wasn't a big deal, so I fixed it by
repairing the drivers, and it worked fine once again...
After using that same crack that you said you used,
I started getting "Multiple Hardware Error"!
It would just Power on, Show HP Logo, Show
Wireless LAN indicator Led ON, and It will freeze
there. I could not even enter the BIOS.
In short ....Now as I'm typing, the system is
with HP Service Centre for they have to change the
Mainboard Outrightly!
So PLEASE, if your system was not specified
Windows 7, use the Operating Systems that it
supports.
Then go to HP Website and download the original
BIOS settngs for your Laptop then repair your
system with it.
But if it is the one that came with it, then let me know
so as to tell you some quick fixes.
Hope this helps you out.
Goodluck and thanks for using fixya!
SOURCE: how we enter the hp compaq Ml-350 server bios
At startup before OS is loaded you will be prompted to press F8 to enter system setup at this point press F8. This message only last a few second. If you didn't get it the first time reboot the system and pay attention to get this message.
