Question about Kitchen Ranges
Gas range makes buzzing sound which goes away when disconnected from electrical outlet.
My gas range started making a buzzing sound which is similar to the timer and is originating from behind the clock area. However, adjusting the clock and timer buttons does not eliminate the sound. Disconnecting the range from the electrical outlet is the only way to quiet the sound.
  • Anonymous Nov 25, 2008
    I have the same problem with a Whirlpool Electric range. The noise isn't constant. Sometimes I will plug it in with no noise but within a few hours or even a day or so later, the sound will start again.
  • Anonymous Jan 02, 2009
    my problem is similar. The buzz sound only goes away when I lock the cooktop.
    Any idea on what could be the problem?
    Thanks
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
Possible to have abad relay on the circuit board itself, only real way to fix is to replace the control board assy
Posted on Nov 04, 2008
Call the manufacturer. Chances are it's a common problem and they already know about it.
Ben C.
BensDiscountSupply
SOURCE:
Why does my electric range makes abuzzing noise every few minute
How do I find out the cause of a low frequency hum in my ...
answers.angieslist.com > Home > Other
May 6, 2013 - Can hear it a bit outdoors in the back of my house. ... Edit Answer (for another -17 minute) ... floor in each room of the house - water sourced noise goes a long ways, ... 8) - gas control valve or electric control box on a gas furnace, or its ... These will commonly make a hum or wheeze sound, for only for a few ...
Induction unit makes buzzing sound - Seasoned Advice
cooking.stackexchange.com/.../induction-unit-makes-buzzing-sound
Mar 1, 2011 - But my accidental activation rate is still well above acceptable on all ... So if the buzz is normal for induction cooking today, why did they ... gas ranges vs induction ranges with some notes on which pans worked ... A good service and re- positioning of the fans on their axles always clears my noise problems.
Dec 29, 2015 | Kitchen Ranges
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
I have an electric dryer, Estate by Whirlpool, It runs perfectly fine on no heat, it also works well on the cool down cycle of a regular cycle. However, if you try to use it on anything else, when you push...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 16, 2011 | Dryers
Kenmore gas stove makes a buzzing sound
Is the door locked?? Is it an electronic buzzer sound??
hold the CLEAR button for 3 seconds - the door will unlock.
open the door - and press CLEAR for 3 seconds.
Error code may come up.... close and re-open the door.
Are there any indications on the display?
Or is this a mechanical buzzing from underneath? in this case your gas regulator's diaphragm has failed.
If the above reset doesnt wokr (and the sound is electric) your circuit board will need replacement.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 09, 2009 | Kenmore Kitchen Ranges
Whirlpool gas dryer makes buzzing sound when started, stops mid-c
Maybe something fell down into the filter housing. Get the back off and inspect it with the power disconnected.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 17, 2009 | Kenmore 62602 Electric Dryer
Buzzing noise
The buzzing you are experiencing is most likely the electric valve solenoid coil.
That is the valve that lets gas in when the stove is turned on.
Another source of buzzing/humming can be a mechanical clock, if hter is one.
If it is digital, then it woul not make noise.
May 20, 2008 | Whirlpool GS563LXSS - stainless Steel Gas...
Oven not working -makes a buzzing sound when turned OFF!
You just need to adjust your door latch assm. Try putting a little oil on the latch and arm. The sound you hear is the solenoid trying to pull the latch arm all the way back to lock the door. Even though it is pulling the arm back and the door locks it may not be all the way back. A little lubrication will fix the problem.
Dec 20, 2007 | Viking VDSC365-6B Dual Fuel (Electric and...
Igniter
Does the knob control both the gas and spark, try turning on the knob only, if it starts to spark right away then it is possible that the switch is bad. because most of these units are designed where you turn on the gas then push in and hold the knob to ignite then release and spark should stop.
Dec 08, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
Premier Pro•Series 36" Model P36S318BP
Sounds like you have shorted out the ignitor module and you may need to replace it. Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into. Hope this helps.
Sep 17, 2007 | Premiere Ranges P36S328BP Stainless Steel...
Kitchen Ranges Logo
807 people viewed this question
Top Kitchen Ranges Experts
Craig Butler
Craig Butler
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
