SOURCE: runs but gun dosenot opreate, it is a clarke 130en
The only things I can think of are:
If none of these solutions solve your problem then I can not help you any further.
SOURCE: clarke en 130 parts
Check out http://www.toledoblade.com/apps/pbcs.dll/article?AID=/20090430/BUSINESS03/904300333 and be angry with the bank, not Clarke.
SOURCE: i need to know what size wire and plug to use on
I would run a 10 AWG wire from the breaker to the outlet, if that is what you are asking. I have the same welder works great just wish I could find a spare wire roller.
SOURCE: Have Clarke MIG 130 EN. replace Power Cable Assembly 23000054
Your local welding supplier would be you first choice. you will be able to fit an alternative power cable, dosn't have to be Carke,
when using the selector switch it will work 1,2,3 but when turned to number 4 no weld? I am wondering if it's a bad swich or something else?
when I use number 1,2,and 3 it will work fine but when number 4 is selected then the blower moter is just on and nothing will happen when I pull the trigger
