SOURCE: hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
SOURCE: hotpoint tumble dryer ctd40g
hi
Timers are driven by synchronous motors. Although the contact part of the timer can be cleaned and adjusted on some dryers, this is a job for a professional repair person. Timer motor repairs should also be handled by a professional, but you can replace a faulty timer yourself. Here's how to test and replace a dryer timer:
Step 1: To access the timer, remove the front of the control panel. On some dryers, the timer can be removed without removing the panel. In either case, pull the timer knob off the shaft and slip off the pointer. The pointer is usually keyed to the shaft by two flat surfaces to keep the pointer from slipping when it's turned.
Step 2: Test the timer with a VOM set to the RX1 scale. Turn the timer to the NORMAL DRY setting and disconnect one of the timer power leads. Some timers may have several wires connected to them: The power leads are usually larger than the other wires, and this size difference can be spotted under close examination. Clip one probe of the meter to each timer terminal. If the meter reads zero, the timer is working. If the needle jumps to a high reading, the timer is faulty and should be replaced. Replace the timer with a new one of the same size and type.
Step 3: To replace the timer, have a helper hold the new timer close to the old one, especially if there are several wires to be changed. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram detailing the proper connections. After all the wires are connected, check the connections again for accuracy.
A dryer that won't heat can't do its job. Learn how to assess heating problems for gas and electric dryers in the next section.
SOURCE: no heat from my tumble dryer
Presumably the motor and fan are working.
Check filter, and if it is vented with a hose, make sure it is not blocked with fluff. if all seems to be o/k, then the heating element is probably faulty.
Please leave good feedback if this helps with your problem
SOURCE: Loud grinding noise when dryer is on aslo blew fuse last night
I suspect that the rear drun bearing is worn allowing the drum to drop, or the front bearings have gone.
Remove belt and try again if noise still persists then the problem is the motor or fans on the motor. They can wear or come loose.
SOURCE: HOTPOINT AQUARIUS CONDENSER TUMBLE DRYER CTD40
Not sure but try this..it workd with my Whirlpool dryer. Remove the condenser (clean it with water and a toothbrush too coz it will probably be clogged up) and pop a tea towel in the hole where the condenser was. Tip the dryer on its side and any trapped water will run out onto the tea towel or the floor OR the water reservoir where it should have gone in the first place......
