My player keeps recycling on and off. can not charge battery,
goes as far as intro screen and eax then shuts down just to start up again.
its a 40g
model number DAP-HD001
I have the Zen Xtra creative 30 Gb. It goes on and off, with battery and without battrey with the charger. The reset button has no effect. Could that be the end of de hard drive ?I have the Zen Xtra creative 30 Gb. It goes on and off, with battery and without battrey with the charger. The reset button has no effect. Could that be the end of de hard drive ?
You can't post conmments that contain an email address.
Whirring noise = bad, probably needs to be replaced, BUT: Uninstall everything from your PC, reboot, reinstall driver and the Explorer (I do not use MediaSource, only the Explorer).
If it didn't work out follow these steps:
1. Uninstall Creative Media Source and all related software. 2. Install the driver. In the installation CD the driver is usually in \Drivers\English 3. Turn on the Nomad an connect it to the PC. 4. Install MediaSource(the program requires that you have the nomad connected while installing) 5. Install MediaSource plugin 6. Try transferring files.
If
you?re still running into problem know that there are other programs
capable of handling MediaSource?s functions, such as - Portable Audio
Devices Power Toy , NomadSync, Real player, and there?s also a Zen
plugin for the Winamp.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
mine did the same until i got a new power supply. it requires a 5volt dc pos tip charger with 20 watts. a universal 3-7.5v 2amp charger from radioshack does the trick. make sure the tip is yellow for the charger.
