You bought a "new" reconditioned remote and it doesn't work?
You should send it back for exchange or refund.
I haven't encountered reconditioned remotes before. I doubt there is much profit in reconditioning remote controls when new dedicated replacements are available at such reasonable prices. Often new original remotes aren't expensive if they are available.
Have the first remote tested--most shops have a tester--point remote at it and press buttons and it reacts with a flash (the tester) and if remote tests good the problem could be with the remote receiver in the set
I'll have to go with Ironfist109 on their question. You can order a new remote on the website of the manufacturer, but you must get the Model number on the unit to determine what remote you need to order. The model number can be located on the back of the device. Once you have this, you can go the the RCA website, and go to support. From there you can order a new remote. Hope this helps!
you can order a new one by phoning manifacturer with product make it will cost between ten and twenty pounds please give thumbs up if this helps thanks
walmart should take care of you just bring the order number or get a reciept online from where you ordered it but i think walmart will take care of you
Its likely that the new new remote control has specific codes for the components it can operate. You should look to the remote manual or online source to find the code(s) for the DVD player you have. Without knowing the remote you purchased, its hard to locate codes for you.
