NEC Electra Elite DTU 16D-2 Corded Phone Logo
Posted on Mar 14, 2012
How to Change Time on NEC Dterm Series E phone
I have changed the system time but the LCD display time will not change. How can I change it? I've tried 'Feature' 9#. HELP!
  • cphalo
    cphalo Mar 14, 2012
    I press specker the 72...then I get a busy signal. It won't let me press the entire 728. It just gives me a busy signal. Still needing help...
  • Anonymous Nov 26, 2019
    CAT Mode Procedure: This is to be done while the phone is in an idle state.
    1. Press
    2. Press
    3. Press *
    4. Press
    5. Press
    6. Press #
    7. “CAT MODE” displayed on LCD
    8. Press
    9. “COMMAND” displayed on LCD
    10. Press 02
    11. Press
    12. Press 2
    13. Press
    14. “02>2>Current Time” displayed on LCD
    15. Input correct time using military time (HH MM SS)
    16. Press
Daniel Wilson
Level 1:
New Friend:
  • Contributor 21 Answers
  • Posted on Mar 14, 2012
Daniel Wilson
Contributor
Level 1:
New Friend:
Answers
21
Questions
Helped
3975
Points
71
Press the "Speaker" button and enter 728 on the key pad. Then enter the correct time.
How do i change the extension name on the display of NEC Dterm Series i?
Which NEC system is the Dterm Series i connected to? Normally you change the ext name in system programming, but I need to know which system it is.
1helpful
6helpful
Need change the time on my nec phone d term 80
To reset time NEC Dterm 80
Press speaker and enter 728 on keypad.
Then enter correct time in 24 hour format...Ex. 2:56 = 1456
Then press speaker again...
Note: On my system this changes time on all phones on the system
44helpful
2answers
Cannot change time on my Xen IPK Dterm Series i
  • Press Feature, 9 and #
  • Use dial pad to enter hours and minutes
  • Press Recall to change Am / Pm
  • Press Hold to change Date
  • Press Recall to change Day of the week
  • Press # to move cursor to Date
  • Enter Date
  • Press Recall to change Month
  • Press # to move to Year
  • Press Feature button to save
5helpful
Time change
depends on the type of system.
feature 9# enter time.
feature to save
1helpful
NEC dterm series II phones-name desplay
This works on the series E phones. It may or may not work on the series II.
  1. Press the Speaker key (do not use the handset).
  2. Dial the Name Assignment access code and wait for the special dial tone.
  3. Using the key pad spell the name. Press each number until the letter appears.
  4. When the correct letter is displayed Press the HOLD key. Pressing the HOLD key will lock the letter in place and advance to the next position.
  5. Repeat steps 3 and 4 continue to spell the name.
Pressing the TRANSFER key will change the current letter to lower case.
Example to enter the name “Pat” press:
77 HOLD 22 TRANSFER HOLD 88 TRANSFER HOLD
How to change the time
Press Feaure 4, should display Tel 1 or Tel 2, if not, can't change time. Must be admin phone.
195helpful
7answers
Change time on nec dterm80 phone
Press the "Speaker" button and enter 728 on the key pad. Then enter the correct time in 24 hour format. For example at 2.56 p.m. type 1456. Then press speaker again and you're done
Top NEC Lands Phones Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
RAJA NADEEM AKHTER
RAJA NADEEM AKHTER
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
