Televison & Video Logo
peter burnett Posted on Mar 14, 2012
Which remote control do i need for a denon udra 90
Patrick McCreanor
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 01, 2018
Patrick McCreanor
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
238
Points
It is the Denon RC-170.
Denon udra-77 hi the cassete deck will not eject or close on pressing the open close button, the rubber band between the wheel is intact, it will activate when manually turning the top wheel, seems to be...
The mechanism maybe out of alignment. Technicians and a service manual is how this gets fixed. The new belts are put in an the mechanism is position to the stop mode for the eject to work.
I have a Denon reciever model # UDRA - F05 which has gone into 'protection mode'. How do I get it out of protection mode???
Hi There, may I asking you about the remote series for Denon udra-F05 remote, thanks a lot Bro
How do I set the clock on the Denon UDRA-M10 tuner/amplifier?
After you have set your clock time simply just hold down memo button and I goes to minutes and click memo once to save your chosen time.
2helpful
UDRA-F10 displays "Protect" on display- no other function is runnung.
See the link below for an explanation and post any additional questions here.
Thanks,
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
How do i reset my Denon udra m1o tuner amp from protect mode?
Protect mode can not be "reset". This mode means that a problem was detected in the final amp stage and the unit has been shutdown to prevent further damage. The most common cause of this is failed output transistors. Plan on a parts cost in the $20-$20 range for this repair.
Dan
AM,NEED REMOTE CONTROLL DENON AVR-3802 HOW I,BUY?
I had the same problem. Unfortunately Denon no longer mfgs. the remote for this receiver,
their solution is to offer a remote for a "similar" model. Problem is it doesn't work on all the
functions for the AVR-3802. My solution was to purchase an aftermarket universal remote
(Logitec Harmony 550 in my case}. The cost was a little less (approx. $90) vs. the price
quoted by Denon (somewhere around $120), and it works on all the functions.
I don't know if a budget priced remote (All-in-one, etc.) would be able to do th same.
There are several different programmable remotes on the market that should do the trick,
Logitec just happens to be one of them.
Good Luck
Radio preset Denon UDRA-f10 doesn't save
1) tune in to a radiostation
2) press the Memory button
3) select a preset number for 5 Second
4 Skip "press Memory again"
1helpful
My aplifier Denon UDRA F-10 says "protect"
Blingking Light or Protect usually means that there is DC appearing in output stage and is protecting Connected Speakers.
It can be faulty Output Stage (Bad ICs/Transistors/Resistors/Capacitors) or Faulty Power Supply.
Working on These types of Problem is not user friendly at all.
Advising to take local Authorized Shop.
Top Denon Televison & Video Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
