Hi i have a samsung u900 which when i dial any numbers the phone tells me it will only allow emergency calls the phone works well in every other way eg web browsing etc. When i use the sim card from this phone in my other orange phone it works no problems. On the icon bar at the top of the phone it shows up with the telephone icon having a red line through it.
Hope someone can help
SOURCE: transfer numbers to phone from sim?
ive had the same problem, and i dont think its possible. im pretty sure you have to copy them one by one.
SOURCE: Limited Services on my Samsung SGH-D840
i made a couple of calls and it turned out my phone needed flashing to reset all factory and network settings. i took it to a specialist and it cost £20
i'm sure the software to do this yourself is on the NET and you only need the phones USB fire wire to connect it.
SOURCE: about call rejected
try-- go to calls, options, call reject list. See if the number appears there. If it does, remove it.
Is this phone from the same service provider as your simcard? If not, not all phones are unlocked to work with the sim cards of rival companies. If both the phone and sim card are from the sam company, then you can have the company replace your sim card. They usually do this for free as a courtesy as long as you explain the problem to them. Hope this helps
Have you found out why? I have just bought a Tocco on Ebay and got the same problem
has any one found a cure for this yet i have the same problem
I just got my phonr fixed and it is now on emergency mode
I have a samsung tocco whic i went to get fied and now it is constantly in emergency mode. Help!
i have just bought the samsung tocco ultra on vodaphone and have the same problem any ideas ??
