Instruction manual
SOURCE: Tag Heuer Formula 1 Mens watch
This is not a cheap watch....You should send it to a qualified watchmaker or the manufacturer. This watch has to have a pressure test to insure it's water tight. This may require replacement of some or all of the gaskets in the case.I would never recommend that this is something that you should try to do yourself.You would be amazed at the money I make do to improper replacement of JUST the battery.
Donald McPherson, Certified Watchmaker AWCI
www.finewatchmaking.com
WWW.AWCI.Com
SOURCE: early tag heuer professional 200m wrist watch
nice noon ! see for the correct position and press it to back on.thank you ! god bless !...
SOURCE: Change the date on my TAG Watch
if it has hands the winder will be screwed in undo this anti clockwise then click it out once for date twice for time, if this helps please rate me joe
SOURCE: looking for the user manual for Tag Heuer Aquaracer watch
They were just hiding it:
http://ww2.tagheuer.com/_documents/manuals/EI2252_en.pdf
-Tha Mp3 Doctor
SOURCE: I can't seem to set the time on my used tag heuer watch
Probably your watch has a screwdown crown and prior to attempt any
settings you have to unscrew it. Some peoples fingers are stronger then
others, so, try that with a pair of plyers. Cover your crown with a
soft cloth and then grip with plyers(this will avoid any damage).
Thread is right handed and unscrewing is done by turning the crown
anticlockwise.
After setting the time don't forget to screw the crown back- it is for water resistance.
If you are unable to unscrew the crown, that means your watch is rusty and you will need watchmakers help.
PS
If the watch is rusty, you can brake the crown off while trying to
unscrew it. Don't panic yet, as in this case you will need a watchmaker
anyway.
Don't forget to rate, please.
