Where do I buy a Raptor Marina Main Board 2.5 V2R1
SOURCE: I have just purchased a Seagate 500GB Desktop hard drive
There is software preloaded on the disk. If you have AutoPlay turned off in your system, it won't start automatically when you connect the drive. Just go to MyComputer and open the drive and you will find a setup file there to install the backup software (I think it's called Launch.exe).
SOURCE: hi i have a seagate
Yes, it can be fixed - all you need to do is to solder it back. Just make sure you do it properly - use good quality solder, a fine head soldering iron and lots of care.
The board can be easily replaced, but it's not sold as is, you will have to obtain a defective hard disk from a pc repair shop and use its board.
SOURCE: I have seagate 500gb sata
I believe you are looking for this: USB Mini-B (5-pin)
you are looking for the "socket"
Here is a list of products to choose from:
https://www.alliedelec.com/search/searchresults.aspx?N=0&Ntt=USB+Mini+B&Ntk=Primary&i=0&sw=n
Please note; This will be extremely hard. most of those products have no pictures and you are not sure exactly what you are getting, luckily they are pretty cheap so i would recommend getting a couple that sound right.
Good luck, be careful.
Hope this Helps.
