Need to change the ink cartridge but i haven't a clue on how to do this, need step by step instructions. Help please
Document.tlSearch.tx.value=unescape("")
HP Color LaserJet 2600n Printer - Installing Print Cartridges
When a print cartridge approaches the end of useful life, the control panel displays a message
recommending that to order a replacement. The printer can continue to print using the current print
cartridge until the control panel displays a message instructing to replace the cartridge.
The printer uses four colors and has a different print cartridge for each color: black (K), cyan (C),
magenta (M), and yellow (Y).
Replace a print cartridge when the printer control panel displays one of the following messages:
Replace yellow cartridge, Replace magenta cartridge, Replace cyan cartridge, Replace black
cartridge.
The control panel display also indicates the color that should be replaced (unless a
genuine HP cartridge is not currently installed).
Change the print cartridge
NOTE:
If a cartridge is in the wrong slot or is the wrong type for the printer, the control
panel will display one of the following messages: Incorrect yellow, Incorrect magenta,
Incorrect cyan, Incorrect black.
NOTE:
When replacing or changing a black print cartridge, a cleaning page will
automatically print. This helps prevent speckles on the front or back of printed documents.
A cleaning page can also be generated using the control panel or the HP Toolbox.
