Sanyo Xacti VPC-T700 Digital Camera Logo
sue king Posted on Nov 03, 2008
LCD SCREEN I WENT TO TURN ON MY CAMERA AND THE LCD SCREEN IS JUST WHITE WITH A FEW LINES IN IT, SO I CAN NOT TAKE PICTURES WHAT COUDL BE WRONG?
  • KMDe Nov 14, 2008
    I have the same problem. My screen is black with lines. It worked the previous evening and no one dropped it. Why did this occur? Is there anything that can be done to fix it or do I just toss it?
  • jshitesoxfan Nov 21, 2008
    I went to to use my camera one day & when I turned it on the screen was white with blue lines. The screen is not cracked. It can take pictures, but i can't see them, unless i take the memory card & upload them to my computer.
A
Anonymous
Cracked your LCD screen, the black lines are where it broke.
When i play ...It works Perfect..but if i try to Record Screen is in Orange color
The same condition appears when you transfer this pics at PC ? If yes, and the problem continue, first... could be a problem with the LCD viewer screen, or, if not, coudl be the CCD image sensor go to bad; in both cases this isn't a job that you could solve yourself; this wrong include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
I suggest check THIS LINK for additional details in this previous solutions for an Defective CCD (Charge Coupled Device) and next contact your Canon service.
I strongly suggest (taking into consideration the age of your camera) to evaluate the cost of repair versus the cost of a new camera with similar features, before making a final desicion.
Hope this helps
Sep 07, 2011 • Cameras
My photos have multiple blurred lines across photo
If your camera have some "anti-vibration" setup, check if this is activated, or its possible that this system is go to bad or need to be recalibrated.
Hope this helps
1helpful
I have a Sony DSLR A-300 and the lcd screen on the back of the camera goes white when I take pictures. How to fix this?
The camera has live-view, so is the LCD always white? Can you play back old pictures or view menus properly? Do your pictures turn out white or are they ok?
If it's always white and you can't see anything, you need the LCD replaced or the cable going from the main PCB to the LCD replaced. 99% likely the LCD, not the cable.
If you can playback old pictures and view menus... but NEW pictures turn out white then it's not a problem with the LCD screen at all, it's the CMOS or something else.
Without knowing more detail it's hard to say exactly what's wrong, but it definitely sounds like the camera needs repair.
Thomas
White out LCD screen
Try a manual reset. Remove the card and battery...press all the buttons...leave the camera alone for 20 minutes...insert the card and then the battery...turn it on.
When I turn my Nikon L18 on, the LCD illuminates but is all lines
i have a similar problem, is the screen white with occasional lines that look like a badly tuned digital tv? my tv out works so I am guessing its a LCD problem, try replacing the LCD like I am doing...
LCD and Pictures have horizontal lines all over them.
Hmmm... your batteries ok? i had this recently and changed my NMHI batterys and cured it...
Photos have horizontal lines
Ok, first of all......when you transfer the pictures to a computer are the blue lines still in the picture? Also if you reset the camera does the image still come out white?
A lot of times what happens is that there is nothing wrong with the actual picture it is the lcd. When you transfer the picture it looks ok you are only seeing the blue lines on the lcd. That means that the lcd is going out. If you transfer the picture and the blue lines are still in the picture after transfer then we can try to reset the camera as there is something else going on besides the lcd. More that likely it is just an lcd that needs to be replaced.
With a white image that usually means that the white balance is off on the camera. I would recommend resetting the camera and then try retaking some pictures to see if they are still coming out white. If they are then you would have to send the camera in to be repaired.
LCD Screen has vertical lines and now it is almost white
you will need to send it the sony directly for repairs rather then Precisions Camera in CT since they are only a authorized repair center rather then a direct manc. place.
Please call 1 800 282-2848. Best if you have a proof of purchase to go with it.
3answers
White Screen
I have Fuji FinePix 2650 Digital camera with same problem. I can almost guarantee this is not a firmware problem. I went mountain biking a few months ago and take pictures. I take out camera and turn on. I get lines then white screen. I banged on camera and fixed it. Later a few weeks ago I turn it on and white screen. i beat this thing and get bad menu selection screen for a moment then white again. It takes pictures well and talk to computer no problem but no LCD picture. I thinking it is loose connection for LCD. Send it for repair or if you seek adventure try to fix it yourself!
Top Sanyo Cameras Experts
NOEL
NOEL
Ngoro
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
