My washer begins a cycle, gets about halfway through, then stops and displays the message E3 on the LCD. At the same time, there's no water left in the tub. I can't see a leak anywhere underneath the washer- can someone help?
It seems there is a fault on the main controller unit of the washer. It seems to start and then drain off in mid cycle. Now choose a different program and see if there is any change. Also check individually the inlet valve, the water level sensor and also the drain valve. Also check all the connections to the main panel.
how do I check the drain pump hose on my Avanti W798 washer?
my avanti W798 washer won't drain
