There are many ways to clean stained grout. You could try one of the commercial cleaners sold on the market and scrub it with a brush. You can also try creating your own cleaning solution. This way you will avoid using harsh chemicals in your home, which is always a good thing. You could try making a paste of baking soda and some water and use it to scrub the grout with, or you could spread some baking soda on the grout and then pour some vinegar on it. After about half an hour you should be able to scrub off the dirt easily. In some cases the grout is so dirty, that the only option is to remove it and apply new one. You can check the website attached, the professionals there know a lot about tile cleaning and maintenance.
you can wash the bag. However you cannot wash the bag in the wash machine. What you will want to do is look for the screw or depending on the model, untwist the cap down on the rod next to the machine. that entire pole section will come off of the unit below with the bag there.
I recommend if it is warm outside to use the garden hose to spray it and scrub inside the bag with a scrub brush and some dish soap.
I usually throw them into the laundry sink and let soak, scrubbing with soap and water.
To dry the bag, a hairdryer or hang to dry before putting the piece back onto the machine.
Hoover H3000 Floor Mat I have a H3000 Floor Mat the problem is it won’t pick up the water after the scrub clean the floor. What could be the causing the problem? I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The problem could be that the Hoover H3000 Floor Mat could be clogged or something is blocking the suction port or you may have a pinched line of some type of which would cause it to not pickup, feel free to check with a local vacuum dealer in your area or in the yellow pages or the Hoover factory phone number is listed below: http://www.hoover.comTelephone Contact our Customer Service Department at 1.330.499.9499 Monday through Friday 8 a.m. - 7 p.m. EST
