1995 Jeep Grand Cherokee Logo
Posted on Nov 03, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1995 Jeep Grand Cherokee - Setting the clock on the NAV radio
Can't figure out how to set the clock on the NAV radio (REC navigation model).
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 393 Answers
  • Posted on Dec 18, 2008
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
393
Questions
0
Helped
195894
Points
885
Go to system settings from main menu you will see clock settings option
3answers
How do I set the time in my 2005 Jeep Grand Cherokee with navigation
the nav (rec) head is too complex to stuff into the , cars users guide, have paper too, in my jeep, "no phy. time button , for sure"
so JEEP has a manual only for this one head.
85 pages.
solved.
get it and keep if for next time lost in the guts of NAV
the DVD_Rom slot 7 is not optional,. NAV DISC.!
nor is working GPS. and is the default.
for driving maps live all that is needed.
next time post a photo of your head like this.
see this ,see "REC"
bingo. if not bingo say it/?
1helpful
Setting the clock in a 2006 Jeep GC w/ navigation system
Yes this is a little confusing!! It is set from the Nav window. Depress Nav and scroll down to clock.
Depress clock and you can daylight savings option or set clock
Hope this helps?
Other Jeep Radios
1. Press the MENU hard-key on the right side of the
radio.
2. Then press the System Setup soft-key to get to the
System Setup menu.
Set the Time
1. Press the time soft-key in the lower left corner of the
screen.
The minutes are set by the GPS system.
2. Press the Set Time Zone soft-key to change to the
desired time zone.
3. Press the Daylight Savings soft-key to switch Daylight
Savings on or off.
It is possible to set up your own time (ahead or behind
actual GPS time), by pressing the USER CLOCK soft-key.
NAVIGATION 15
1helpful
2answers
2005 Jeep Grand Cherokee Navigation Issue The
Look on ebay for an REC Joystick replacement. In the mean time you can hold down the middle button on the right side of the back of the steering wheel, where you can control the radio features. When you hold this button down, a little red wheel symbol appears on the navigation screen which means you can control the navigation system from the steering wheel controls. This works for simple tasks until you get the replacement joystick. They are about $30 and take about an hour to install.
2answers
The rec nav radio screen has grey black and white lines and nothing else
If you ever found an answer to your problem I would really appreciate the help. Mine just started doing the same thing today. The screen has lines on it but the sound works fine. 2005 Jeep Grand Cherokee Limited. Thanks
6helpful
Eject navigation disk in 2005 Jeep Grand Cherokee
Under the cd slot you will see a long thin rectangle that can be gently pryed out with a knife tip on the right side of the rectangle. under that cover there is a small button. push that and out comes the nav disc. Voila solved
6helpful
2answers
Can not set the clock on my 2005 grand cherokee limited
im a tech at a jeep dealer and i always have trouble remembering how to set the time. but i do know that it is in the navigation menu somewhere under settings or something i hope this helps
Diagnostic display will not stop blinking
You have lost the keep alive memory, either the radio is defective or the fuse for that circuit is burned out.
Radio not working
Radio will light up the clock works
Top Jeep Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Jeep Expert? Answer questions, earn points and help others
