Health & Beauty Logo
A
Anonymous Posted on Feb 28, 2017
Model - SC-300ST Could you help me please? My machine has worked perfectly for a year now but unfortunately for whatever reason, yesterday, when pushing the enter button to take the readings which wou
Model - SC-330ST Could you help me please? My machine has worked perfectly for a year now but unfortunately for whatever reason, yesterday, when pushing the enter button to take the readings which would then normally flash "step on".. Instead 5 half zero's flash & beep with the arrow pointing to weight lock mode! Have I accidentally locked it? There is weight lock on/off button but its not doing anything when pressed. I've also noticed when the flashing & beeping is happening, if I tilt the weighing platform the flashing & beeping stops. Should I be somehow deactivating the weight lock? I've read the instruction manual but cannot find anything about this! Tanita have said there is either something weighing the platform down which there is not or i've dropped it & need it to send to them in the Netherlands to fix! I so hope you have the answer Many thanks Kindest Regards Lee What Tanita have replied.. Like explain in the manual on page 42, there must be an obstacle or something that pushes on the platform, or the platform got dropped. Either way, please send the complete scale to the address below for repair. Optional Information: Make: Tanita Model: SC-330ST Already Tried: Everything the Instruction manual presents Switched on & off Tried to push the weight lock on off button but nothing Have tilted the weighing platform when the machine is malfunctioning & it stops flashing & beeping & tries to take reading
5 Related Answers
Anonymous
  • Posted on Nov 20, 2008
SOURCE: Tanita 2204 Scale weight reading problems
Try the following steps:
1) press both the "set" and the triangle button
2) press the triangle button until you get the desired unit of measurement: a) Kilogram, b) stone lbs or c) lbs; and
3) press the "set" button.
Anonymous
  • 463 Answers
  • Posted on Mar 16, 2009
SOURCE: My Scale stoped weighing me, now it reads 1-ld .
The sensor has been worn out or has been pushed past it's weight limit. When you get on it, it pushed the sensor past the point of working... When she gets on it, no problemo...
Anonymous
  • 208 Answers
  • Posted on Jun 22, 2009
SOURCE: Inaccurate Readings
time to buy a new scale :)
Anonymous
  • 15935 Answers
  • Posted on Sep 05, 2010
SOURCE: Tanita BD-590 calibration
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Anonymous
  • Posted on Apr 28, 2011
SOURCE: What is Err 5 ? I have just bought the scales and
Too much body water composition. Are you extremely overweight?
Testimonial: "We got a copy of the manual which had all the Err readings, and it mentioned water composition. We assumed your answer was the issue - now it works."
Just today, it does not give any display; yesterday it worked perfect.
Even though it is the original one, but the electronics needs using frequncyly in their lifetime. If you didn't make it, it will be useless.
Hi i have a Panasonic surround sound model SBWA15 which is about 5 years old. The machine switches off and displays 'F76' in the display screen. i took it to a repair shop and they say the outputter has...
I have PANASONIC MODEL NO. SB-WA15, the radio works but when i try to work it witht he t.v. it does not come through the speakers. what do i do? i need help before the superbowl tonight!
Where is the wireless button on laptop acer aspire 452. I cannot get a wireless connection with my router. The help screen says that the wireless radio is off. I just used it as wireless yesterday, the...
hi, Acer usually has a utility called "Acer eNet Management" to turn wireless on/off and several other things.
here download this manual for acer laptop it will help you out exploring your laptop more...
(start)
http://global-download.acer.com/GDFiles/Document/User%20Manual/Prespa%20AS%20ENG_Starter_OLM.zip?acerid=633646662894100968&Step1=Notebook&Step2=Aspire&Step3=Aspire 5570&OS=V10&LC=en&BC=Acer&SC=PA_6
(end)
copy paste the complete link between (start) and (end) not including (start) (end)in explorer or whatever browser you use it should give direct download for manual...
if this doesn't work for some reason, go to acer.com, click on support, then download select your model, you will notice by defaull driver Tab is shown, but if you look to the left of it says "Document" click on it and download it.
hope this helps...
Amar Sondhi
13helpful
Tablet will not turn on
I had the exact same problem. Finally, I pressed all the three buttons, power, left click and right click buttons and held it for several seconds. After that, the tablet turned on.
1helpful
Some of my Buttons don't work on my microwave
Chances are your keypad has failed.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If yours is not found there, please reply back with your brand and model.
If you don;t prefer to repair it yourself we can help.
Top Tanita Health & Beauty Experts
TUSHAR PANDYA
TUSHAR PANDYA
Level 1 Expert
john h
ADMIN Andrew
ADMIN Andrew
Are you a Tanita Health and Beauty Expert? Answer questions, earn points and help others
