Multi media audio controller
pci simple communications contoller
sm bus control
video controller vga compatable
all with yellow question mark against them
you must turn one of ,one driver will be for Ethernet the other for wifi.right hand side connect icon right click go to network and sharing ,left hand side up top change adapter choose the one you want.as the the yellow marks its telling those drivers are missing.you need either to download them or look for your driver or motherboard disc as the drivers will be on there.
HP.com
2005 RELIC PC.
HP owns and sold Compaq 2002 to 2013 (now ended)
HP also now ended all support on some compaq's (oldest)
XP THE VIRUS MAGNET ENDED 2014 SO WHY USE XP??????
Hi
This is the software issue. Need to install the appropriate software to reslove this issue.
1.Ethernet controler - Need to install the chipset driver and the Lan driver
2.Pci bus device - Chipset driver
3. sm bus controller - After installation of the Chipset driver - Right click on the sm bus controller and update the driver - select install from specific location - i will chose the location- Select the model and hardware type as thermal sensor
next - follow the instruction.
4. video controller - Need to install the VGA or Display driver
5. video controller (vga compatiable) - Need to install the VGA or Display driver
i need drivers for my satellite L310, PLS HELP ME CNF7051 ETHERNET CONTROLLER MASS STORAGE CONTROLLER MODEM DEVICE ON HIGH DEFINITION AUDIO BUS PCI DEVICE SM BUS CONTROLLER VIDEO CONTOLLER VIDEO CONTROLLER(VGA) UNKNOWN DEVICE
i hope u re install your operating system,
after the re installation u did not install the drivers that is the reson, best way u buy an ethernet card and try to get net connection and down load the drivers from dell.com ,then remove the card ,thats it.
