The
problem could be due to a communication failure between one of the printheads
(cartridges) and the All-In One (AIO) or by a short in one if the printheads. Please follow the steps
below to identify and fix cartridge issues:
SOURCE: Refilled Cartridge
I have a Lexmark X7170 with the same type problem. Refilled without a prob for many times. The last time I couldn't use it after refill and bought a new cartridge which is already out of ink. I refilled it and after installing it I get a message that the cartridge is missing and the alignment won't work
BUT
Icalled my ink supplier to see if they knew of an anti refill device put in by Lexmark and they said that they had not heard this.. While talking I remembered that the previously I got a message while printing that the cartridge was missing but if I clicked OK the printer printed without a problem! So maybe yoy just need to skip the alignment, ignore the messages and try to print anyway. The last one I refilled is now working .
Another possibility is that after some number of refills the cartridges just quit and you need to occasionally purchase a new one - this I heard previously from my supplier
Good Luck
BL.
SOURCE: Lexmark X4650
Here is how to align your print cartridges
Using the printer control panel:
1 Load plain Letter-size paper.
2 From the printer control panel, press tools , and then press ok.
3 Press the arrow buttons until Align Cartridges appears, and then press ok. An alignment page prints.
Using Windows
2 Do one of the following:
• In Windows Vista, click the windows globe (start button) .
• In Windows XP and earlier, click Start.
3 Click All Programs or Programs, and then select the printer program folder from the list.
4 From the printer folder, click Maintenance Align Cartridges.
5 Click Print.
6 Follow the instructions on the computer screen.
Using Macintosh
2 From the Finder desktop, double-click the printer folder.
3 Double-click the printer utility icon.
4 From the Maintenance tab, click Print Alignment Page.
5 Follow the instructions on the computer screen.
If you aligned the cartridges to improve print
SOURCE: lexmark x4550 install new cartridge but printer read incorrect
Are you using a Lexmark factory new cartridge or a re-filled / third party cartridge. If the answer is that you are using re-filled or a third party cartridge that is your failure. Lexmark does not support the use of these products in there products. In fact, use of these type of products is considered to be -product tampering and will cause Lexmark to void the printer's warranty. Please do not shoot the messenger for the contents of the message. Truth is Truth!
SOURCE: I have a lexmark x4550. replaced the color
your color cartridge is damage change it and insert niw cartridge
I put the old cartridge in and got the same error.
If replacing your cartridge does not help, please contact Lexmark Technical Support Center for further diagnostics.
