Touch panel blank, microwave runs if door is shut. Should we replace panel for $127 or replace entire oven if not the issue?
SOURCE: door indicator prevents microwave from starting
This is usually an indication of a bad door interlock. Take resistance readings with the power turned off on the primary and secondary interlocks. You will need to remove the control panel to access them. There should be a wiring diagram somewhere inside the control panel to assist you in determining if the interlock is normally OPEN, or normally CLOSED. As you open and close the door the interlock should change states. Additionally, double all your connectors to make sure they are plugged in correctly. I had a similar problem once and it turned out to be a loose connection on one of the interlocks. I hope this helps you.
SOURCE: Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
SOURCE: Looking to replace the plastic piece on the
They don't show the entire door assembly as being available.
But you can replace the outer door frame (outer door panel)part number 8184319.
At $167.94, it's not cheap. But you can get it here.
You have to
separate the door panels (as shown in the attached photo)
and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I
made) that demonstrates how it's done.
In some cases, you then
have to gently rotate the handle to unlock it.
You can find
helpful exploded view diagrams and order parts by entering your full
model number here.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
SOURCE: How do i replace the door handle
with most microwave ovens, for safety reasons... they are permanently sealed to prevent microwave leakage burns... i hope this helped you out..
SOURCE: microwave oven door heavy
If one of your door springs has failed, you will need to replace both, as well as any associated hardware that has failed.
You can find
links to helpful exploded view diagrams and part ordering help
here.
