Question about LeapFrog Leappad Plus Writing
LeapPad start-up screen frozen
Will not boot up. Is stuck on the start up screen. I can't connect to LeapFrog Connect to repair or reset. Is there another way to reset?
  • 5 more comments
  • justaskdalla
    justaskdalla Dec 12, 2012
    I FOUND IT!!!!! Here you go! I am not sure why Leappad doesn't publish this but here is how you fix a frozen leappad explore, they emailed me this when I called in: Kindly try these steps which should put the LeapPad into a reset/tune up mode: 1) Begin with the LeapPad turned off and the LeapFrog Connect application running on your computer. 2) Hold down these three buttons at the same time: - Right on the DPad (Since the device can be rotated two ways, the right arrow is on the right side of the DPAD when you are holding it in portrait mode) - Home - Down Volume 3) While holding down all 3 buttons , press the power button to turn the LeapPad on. 4) When it powers on, it will have an image of a LeapPad with a yellow triangle on the screen 5) Connect the LeapPad to the computer. Please follow the steps below for the Repair/Reset after the Tune Up: Open the LeapFrog Connect Application 1. Click Settings at the top of your screen. 2. To fix an issue with the LeapPad tablet, click Repair. To erase all files and game play data from the device, click Reset. Note: The need to reset the LeapPad handheld is uncommon and is to be used with caution. It will erase ALL of the player names, game progress, play data, badges and Micromods from both the handheld and the LeapFrog Connect Application. You will need to create new player names on the handheld, and reconnect the LeapPad handheld to use the LeapFrog Connect Application.
  • jennie_m_pac
    jennie_m_pac Dec 25, 2012
    Thank you so much! It's Christmas Eve and I opened our sons Leap Pad to find it wouldn't go past the opening screen. I was seriously distraut! Then I found this solution and it worked perfectly. Thanks so much!!
  • amandahjoyce Apr 04, 2013
    Super awesome!!! I thought I was going to cry when it wouldn't come on.. so far it's working okay it's hooked up to the application and transferring files or whatever.. hope this works!!!! THANK YOU!!!
  • theivyfamily
    theivyfamily Apr 07, 2013
    thanks, this really works
  • kathablackwe
    kathablackwe Apr 12, 2013
    I tried this, bur the tune up never got passed 8%
  • reddington35
    reddington35 Jul 03, 2013
    Thank you Thank you Thank you!!!!.....@kathablackwe.....be patient.....it took a looooong time to progress.....just leave it for a while.
  • Danma2244
    Danma2244 Dec 15, 2013
    still stuck tuning at 7% for a day now. Any other options?
    New Friend:
Same problem here my daughter is flipping out!
Posted on Dec 12, 2012
SOURCE:
damneddle
  • 1607 Answers
SOURCE: I am trying to connect
The Eject button appears when a Leapster2 handheld is connected and turned on. When you have finished configuring the Leapster2 handheld and your child wants to play with it, you can click the Eject button to disconnect the device. Once ejected, a message will appear letting you know that it is safe to disconnect the Leapster2 handheld from the computer. It is not really a "button" but a picture of a green button which says "EJECT". It should be located on the upper right corner of your screen.
Posted on Oct 12, 2011
  • 36 Answers
SOURCE: Error says that leapfrog connect could not start
hm cant
Posted on Jan 10, 2011
SOURCE: Installed Leapfrog Connect for my
I'm having the same problem! Did you ever get it to work?
-Linda
Posted on Sep 22, 2011
SOURCE: I'm using Windows 7 64-bit.
I am having the same problem, contacted Tag (who is only there during work hours which really does not help) they supplied me with an alt connect file. That did not work either. Have you found a solution yet?
Kat
Posted on Jun 21, 2011
SOURCE: I boaght 2 Leapster Explorers.
This issue is most probably being caused by an intermittent disconnection from the requesting host (your computer) to the file file server (website). You can either use a download manager to download your files so even if the "request" disconnects, the download manager can manage to resume the download once the connection gets back.
You can get a free download manager here: FlashGet Download Link
Click on "download the latest version" on the right hand side and install the software. Download the LeapFrog application using FlashGet.
Hope this works for you.
Posted on Jul 09, 2011
Forgot code for the leap frog and it wont let me get wifi
Wi-Fi Troubleshooting - LeapFrog
www.leapfrog.com > ... > LeapPad Ultra & Ultra XDi
LeapFrog EnterprisesPlease note: If you have gone through all the available troubleshooting on this page and still cannot connect to Wi-Fi, you can purchase and sync apps to your ...
LeapFrog Customer Support ' Help & Support For LeapFrog ...
www.leapfrog.com/en-us/support
LeapFrog EnterprisesKid-Proof LeapPad Warranty ... LeapPad Ultra Getting Started Video ... I forgot the Parent Lock code for LeapTV, how can I access Parent Settings? What is the ...
LeapPad Wi-Fi Support: Setup - LeapFrog
www.leapfrog.com > ... > Wi-Fi Troubleshooting
LeapFrog EnterprisesIf you need to set up your LeapPad's Wi-Fi connection, please click on of the links ... Click here to view the step-by-step instructions on changing the current Wi-Fi ...
LeapPad Ultra - Parent Settings - LeapFrog
Feb 03, 2016 | Toys
For 4 digit pass code on my leappad ultra
Resetting your leappad ultra isa breeze. First thing you need to do is to download and install Leapfrog connect. If it doesn`t download, there`s an offline download option available. After installing it, connect your leappad ultra with the usb cable to the pc. power it on. it should get connected. If it doesn`t maybe your anti virus software is blocking it. If this happens, go to your antivirus software settings and under firewall rules, select allow for leapfrog connect .exe. Then it should detect your leappad ultra. Go to left hand top corner , select My Products. Then select your leappad ultra. Then goto Settings on the right top corner and in the pop up, select Reset. It will take around 15 - 20 mins to reset it. All data will be erased. Hope it helps
http://youtu.be/dnyle_-2aDYw
Dec 02, 2014 | LeapFrog LeapPad Ultra eBook: DisneyPixar...
How to reset
Download and install Leapfrog connect. After installing it, connect your leappad ultra with the usb cable to the pc. power it on. it should get connected. If it doesn't maybe your anti virus software is blocking it. If this happens, go to your antivirus software settings and under firewall rules, select allow for leapfrog connect .exe. Then it should detect your leappad ultra. Go to left hand top corner , select My Products. Then select your leappad ultra. Then goto Settings on the right top corner and in the pop up, select Reset. It will take around 15 - 20 mins to reset it. All data will be erased.
Oct 18, 2014 | LeapFrog LeapPad Ultra eBook: DisneyPixar...
Factory reset of leappad ultra
Download and install Leapfrog connect. If it doesn't download, there's an offline download option available. After installing it, connect your leappad ultra with the usb cable to the pc. power it on. it should get connected. If it doesn't maybe your anti virus software is blocking it. If this happens, go to your antivirus software settings and under firewall rules, select allow for leapfrog connect .exe. Then it should detect your leappad ultra. Go to left hand top corner , select My Products. Then select your leappad ultra. Then goto Settings on the right top corner and in the pop up, select Reset. It will take around 15 - 20 mins to reset it. All data will be erased.
Sep 12, 2013 | Toys
How do i reset my leappad 2
Hi JOHN, first try recalibrating it, instructions on how to do that are here:http://leapfrog.custhelp.com/app/answers/detail/a_id/2225
If calibration doesn't resolve the issue, you can reset the LeapPad with these steps:
1) Launch the LeapFrog Connect application
2) Press and hold down Ctrl + Shift + R
3) A pop up window will prompt you to connect the device you wish to reset
4) Power on and connect the LeapPad
Dec 26, 2012 | LeapFrog LeapPad2 Explorer - Pink
Leap pad explorer stuck on startup screen
All of these are worthless answer given by bots.
Hold down the volume down, home key and the right directional key.....wait till it shows the usb cable icon. connect to your pc with leappad connect software....tune and then select repair.
Oct 21, 2012 | LeapFrog Leappad Explorer Learning Tablet...
My son's leappad turns on but stays on the leappad start up screen. I have tried new batteries, no luck. After some research I found that you can repair or reset it on the leappad connect. Howe
This site is worthless...more interested in tricking you with AD links than giving you an answer. Press Volume Down, Home and Right Directional...then power on. Connection screen will appear, connect it to your PC and select repair after tune up is done.
Then delete your profile on here and report the link you followed from google as worthless.
May 17, 2012 | LeapFrog Leappad Explorer Learning Tablet...
LeapPad stuck on Leap Frog screen.
I have the same problem. did you ever find an answer???
Feb 17, 2012 | LeapFrog Leappad Plus Writing
Leappad tuneup stuck at 5%
This toy sucks. I've had a really crappy year, but three months ago I had a good month and had a little extra to spare so I decided to buy, for Christmas the Leappads my two daughters had been asking for since last year's Christmas.
All good? NO! After being very excited and seeing the happiness on my two little girls's faces when they saw their gifts I was very happy with the way this year was ending. Until it came time to get a few "apps" and connect to the internet etc. with these things. Nothing works, no updates, no registrations, nothing. To add insult to injury, I've my proof of purchase for these two items has been lost and I now have to sit my two little kids down tomorrow to let them know that their "dream gifts" are useless and may remain that way for the foreseeable future. I've plugged a lot of stuff into my computer and have never had any problems, until this little kid's toy came along and nothing works.
Way to go LeapFrog. I followed your instructions and am now stuck with two absolutely useless toys after spending the bulk of my Christmas day trying to get these stupid things to work!!!
Dec 25, 2011 | Toys
LeapFrog Leappad Plus Writing Logo
7,262 people viewed this question
Top LeapFrog Toys Experts
Nikki  Mclean
Nikki Mclean
pramey3
Level 1 Expert
Keith Koene
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
