It ***** off numerous times and has this green blinking light under the word lamp.. we have to wait for the green light to stop flashing before we can turn the tv back on.
SOURCE: flashing green timer light
The Chassis Assembly will need to be sent to Mitsubishi for them to refurb. I would estimate the cost to be 850.00 to 900.00. A Authorizes Service Facility would have to confirm this.
Hope this helps.
Skyassoc
SOURCE: mitsubishi wd-62825 dlp
The WD62825 has a Digital Module located on the left side of the chassis looking at it from the rear of the set. It's housed in a metal box that can slide out of its holder after removing the trim screws.
The module has its own power supply board and there are a group of 16v/1000uf caps on that board which commonly fail causing the constant flashing standby light. Further back on the module is a small board about the size of a matchbook called the E2P module. Its SMT (Surface Mount Technology) caps also commonly fail which can cause the same symptoms. Techs can tell whether the E2P has failed by simply removing it, hooking the DM back up and trying to power the set. If it powers on the picture won't be much good - but at least you can tell what's keeping it down...
Back to the caps on the pwr board. If they've failed they usually will buldge visibly on top. And ESR is almost not necessary. In any event that's the nuts and bolts on this model.
Is it a job for a layman? Yes and no - you might strongly consider a tech if you don't feel comfortable removing all the connections that the DM has with the signal board. There are about six - multi-pin - wired connections to unplug and then sliding the DM out of the unit and carefully removing the screws and latching to take the DM top cover off...
Hope this helps.
Bill
SOURCE: WD-62327 Lamp
Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977020 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977020 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977020 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977020 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 934C148001
SOURCE: green status light keeps blinking after lamp replacement
continuous blinking green light indicates that the capacitors have failed on the DM pwb. You need the V26 DLP DM repair kit which is available at the following link under their repair category.
http://servicemanuals.vstore.ca/
If the green front panel LED blinks continuously and the TV never comes on, its an issue with the "DM" board. When these TVs are first plugged in, the green LED should blink for 30 sec. to a minute or so. This is the TV booting up, reading its software. Mitsubishi has been having problems with this circuit for several years. In may cases the only permanent solution is to have the chassis rebuilt by Mitsubishi at considerable cost and inconvience. The chassis may have to be sent back to Mits for this rebuild. Call Mits and ask for help.
michtech
